Question about Hoover SE230 Front Load Washer
Banging while spinning
When spinning the machine makes a load banging noise as if something on the inside of the machine is banging against the caseing?
  • Anonymous Dec 14, 2007
    We are having the same problem Did you get any assistance
    did anyone get any solutions
  • 46 Answers
Slid the machine out away from the wall and tilt back enough to see underneath. just below the door there is a large concrete weight. chances are it is loose and needs to be tightened. if this problem has been going on for a while the bolts holding the weight on will have snaped and the drum/weight or both will need replacing . ( ex hoover engineer)
Posted on Feb 08, 2008
My Kenmore model # 20642 991 leaks water when it spins (mostly with large loads) and the barrel inside seems to be loose or something because it bangs hard against the inside - sounds like the whole...
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub. The banging noise is due to being unbalanced. You may need to replace the balance ring on the top of the drum inside the washer. Watch this Video to see if this is how your machine is acting.
Nov 26, 2010 | Kenmore Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Banging noise on spin cycle
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
May 09, 2009 | Washing Machines
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Thumping and banging
washing machine making noise, remove water but doesn't spin
Jan 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Hoover SE230 Front Load Washer Logo
482 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
