Question about HP LaserJet 8150 Printer
What does the error message EI0 1 Mean on the 8150dn printer?
  • 27 Answers
EIO is the External Input Output slot that is on the formatter of the printer. the 8150 has 2 EIO slots (EIO 0 or EIO 1). One of the slots is probably the JetDirect card (network card) for the printer. The second slot might be a hard drive but is usually open.
If you are getting a EIO error first try reseating the JetDirect card (power off the printer first). If you are still getting the error pull the card and power up the device with out the card installed. if the error goes away power down the unit and install the card in the other EIO slot. if the card works you have a bad slot on the formatter but you should be good to use the device. If you get another EIO error the card is probably bad.
Posted on Mar 13, 2015
3 Suggested Answers
POCBM
  • 121 Answers
SOURCE: hp 8150 io error
Most I/O errors are the jetdirect card. You can try removing and reinstalling the card. You can also try installing the card in other MIO slot.
If the card is a jetdirect 615 failure is common replace with the 620.
Posted on Mar 06, 2009
  • 34 Answers
SOURCE: HP 8150DN I got 50.1 Error message so I replace low voltage powe
Yes, 50.1 refers to the fuser, and that is very easily replaceable. (no tools) However, in the 8100, you have a 75% chance that it is indeed the low volt power supply. The low volt power supply powers the fuser.
As a service approach, I always replace the fuser first because it is so easy to do and we always have them in stock.
If that does NOT clear the error, then we KNOW it is the low volt power supply. That is a very straightforward repair.
Posted on Mar 17, 2009
62.0 error
62.XX error
There is a problem with the printer's memory. The x value refers to the location of the problem:
0 = Internal memory
1 to 3 = DIMM slots 1, 2, or 3
Recommended Action
Reseat or replace the specified
DIMM
It might also be the formatter but start with reseating the DIMMs
Dec 04, 2013 | HP LaserJet 8150dn Printer
Error 0.000000 aa
Error 0.000000 aa does not exist within HP Service manual, this said I have come across a few errors that dont exist, I would ask If the machine Sounds like its trying to come to ready ( eg can you hear the engine motors turning, does the fuser get warm, if so I would recommend you change the display As it could be a spurious error from the display module -or in the case the machine immediately displays the message without any motors turning or no heating of the fuser rollers , then I would recommend you start by replacing the firmware then the memory , finally the formatter in that order. hope this helps
Sep 25, 2013 | HP LaserJet 8150dn Printer
PCL XL error hp8150DN windows server 2003 for
Depending on what you are trying to print you might try updating the PCL driver or switching to a PostScript PS driver. the discrete drivers for that device were last updated in 2007.
Good luck
Aug 17, 2013 | HP LaserJet 8150dn Printer
Error msg. "50.1 Fuser Error" Turning printer
Hello Pls replace the fuser with new one your problem will be resolved if problem persists then replace the dc controller bord.
Oct 28, 2010 | HP LaserJet 8150dn Printer
Lan setup in hp 8150dn printer
If you go in to the menu system you can print off a menu map for the printer.this will show you the path through the menu system you need to take to get to the menu setup for the LAN settings.
Oct 12, 2009 | HP LaserJet 8150dn Printer
HP 8150DN I got 50.1 Error message so I replace low voltage power supply and know I get 51.1 error message now
Mar 04, 2009 | HP LaserJet 8100n Printer
Hp-8100 50.1 fuser error (James Cho)
And if that does not fix your problem, you may BE SURE that it is the low voltage power supply. Your chances are 25% fuser and 75% that it is low voltagepower supply.
Jul 14, 2008 | HP LaserJet 8150dn Printer
Hp 8150 io error
Jul 03, 2008 | HP LaserJet 8150dn Printer
HP LaserJet 8150 Printer Logo
463 people viewed this question
Clive
Clive
