Question about Standard (CRT) Televisions
1988 zenith t.v.
Is it worth fixing the t.v. if it has water damaged or should i just get it replaced
  • 22 Answers
Re: 1988 zenith t.v.
At almost 20 years old, you are best off replacing it. Parts may be scarce for an almost 20 year old unit.
Posted on Nov 14, 2007
0 characters
3 Points
Zenith tv volume
test the volume switch for open or faulty or desolder wires 2) the board or sound can be faulty need repair. 3) speaker test for coil open or desolder wires
God bless you
Jul 10, 2013 | Standard (CRT) Televisions
How do I remove and replace a Picture tube in a Zenith Tv.
a picture tube you may be able to get from Zenith. Honestly this tube would probly cost you the same as sending the tv to a E-waste event and picking up another. may just not be worth the money to replace.
Nov 09, 2009 | Zenith B27A11Z 27" TV
I have a 15 year old Zenith console, SL2737RK, lost vertical defl
You need to resolder the vertical IC and replace any electrolytic caps in the same immediate area. If you can find someone with electronics experience they know what I'm saying....It can be repaired.
Sep 24, 2009 | Standard (CRT) Televisions
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
Blurred picture and it's also dark rear projection zenith Z52Z95D
I'd get the lamp replaced for sure. If it has a ballast - change that at the same time. However, a Zenith repair center should be able to tell you whether it's worth doing or not.
Jan 05, 2009 | Zenith Z52Z95D TV
I do not have a Zenith B25A02Z TV. What I do have is a 1988 Zenith Color TV SE2517P. I called a local tv repairman and discussed the problem over the phone. He can take a look at it if we bring it in (service call to the home cost $100 just to show up). He said it was worth fixing since he thought it was only the sound. We have a great picture. He charges $20 to look at it but we have to leave it. He lives 20 minutes away one way. We think it is worth the trip if we can get it loaded into our minivan. We live in western NY where the weather can get pretty ugly many days. I will post the solution later when I know. FYI
Dec 30, 2008 | Zenith B25A02Z TV
TV went "pop"
prob not worth repair sounds like horiz sweep circuit. 150 200 to repair.
Nov 30, 2008 | Zenith A32B41W 32" TV
Old zenith intermittent power on problem
would need a model number and if it that old wouldn't advise in fixing it.
Oct 10, 2007 | RCA F27442 27" TV
Picture is dark
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Mar 03, 2007 | Zenith Z27X22D 27" TV
Standard (CRT) Televisions Logo
128 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
