Back to:
Tags:
PC Laptops
Generic problem for all PC Laptops
Starting up programs affects screen visibility
posted by TreaNes on Nov 13, 2007
Recently this started happening and I have NO idea why or how to fix it-- when I start up my computer everything is normal---until I open ANY program whether it be internet, defragmenter, a folder, an application, etc, as soon as I do suddenly my screen becomes extremely bright and the visibility gets really bad. Lowering the brightness on the screen does not help whatsoever-- it just stays somewhat bright and fonts and images become very difficult to see/read. Any idea as to what is causing this????
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 16, 2007
Not Rated (0)
rwedinburgh
Rank:Wiz Wiz
Rating: 84%, 74 votes
This would almost have to be a video driver problem. Try the WIndows default video drivers for some common settings (like 1024x768) and reboot and see if this fixes it. If it does, the problem is video drivers - download the latest from the web and install them.
If this doesn't fix it, try reinstalling the latest version of DirectX. Also, try stepping down VIDEO HARDWARE ACCELERATION through the video settings display panel. Finally, if it really only does it when you run a new program, as a last resort, you can try to reinstall the operating system from scratch and install the latest drivers from the laptop manufacturer.
Good luck...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Starting up programs affects screen visibility:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
HP Pavilion ze2000 PC Notebook
Hello, please i need to recover ma system (HP Pavilion...
PC Laptops
toshiba satelite a100 model psaa5a-01h00t will not play...
PC Laptops
I am having bsnl broadband connection with Siemens C2110...
Toshiba Satellite A135-S2276 PC Notebook
The A135-S2276 will not play DVD's Or CD's. The lite on...
Dell Latitude D600 PC Notebook
battery not charging unless connected to elecrticity plug...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
