Question about Acer Aspire 5002WLMi Notebook
Acer aspire 5020
My laptop jst suddenly started freezing after a while i got fed up because i checked in the event id to see if there were any error reports and there was nothing so i reinstalled using the disks that came with it i was just getting to the part of downloading updates and yep it freezed is there anything you can suggest for me to do to try to source the problem
many thanks
  • 46 Answers
Re: acer aspire 5020
Could be problem whit the memory, download this software, it is a memory testes for windows to see if there some problem whit the memory.
Coul also to be the harddisk problem, but i think not.
Graphics try to download the latest drivers for our graphic card.
But try first to test the memory.
Posted on Nov 13, 2007
0 characters
3 Points
I have an Acer Aspire 122P and all the time I am receiving AMD system errors, Does anyon have an answer what is going on and how to fix it?
I would firstly check that all windows updates have been installed and then run a registry cleaning programme.
Jan 06, 2014 | Acer Aspire One PC Notebook
Acer 5542 freezes
You can start by checking the Event Viewer. Right click My Computer / Manage. Check System for Errors and Warnings. They can be very technical, but most likely there is some event. Check Application as well. There is a Filter option under View. Leave Warning and Error checked.
A helpful tip.
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 06, 2012 | PC Laptops
I have a aspire 7535-5020. It says that it can play blu-ray disc and it's not reading it what is going on?
could you check this link , click Technical specification your Aspire® 7535-5020 does not support blu-ray Media
Mar 07, 2010 | Acer Aspire One PC Notebook
When i turn on my laptop it's starts loading the windows xp and all of a sudden it freeze. And also i wanna know where i can buy a new motherboard for my acer laptop aspire 5100.
You might want to go into the bios to turn off halt on all errors,except keyboard.also pressing escape befor it freezes may let you see what is causing the problem while booting up. Maybe come up in safe made,to eliminate lots of taxing stuff. unhook any new stuff you may still have attached. also make sure cd or dvd disk drives are empty.Good luck!
Jan 26, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 4720z WIndows Vista- crashes every day
there is a programme on the pc that is not compatable with vista, this is called "hanging" this is a common problem with vista as it is not compatable with certain programmes and hardware, you need to find the software that is causing the hang, go to the event viewer by right clicking on "my computer" and select "manage" select event viewer and the software, that will tell you which programme is causing the hang/freeze and uninstall it
Nov 16, 2008 | Acer Aspire 4720 Notebook
Acer 5020
I assume you get power go to your laptop
Try to reseat memory first.
if you have 2 memory, try to use 1 memory at 1 times.
if using 1 memory is working, try to put another memory.
if reseating memory isnot working, your motheboard could be bad.
May 01, 2008 | Acer Aspire 5100-5022 Notebook
Why now acer.
YOU HAVE PROBLEM WITH YOUR HDD try to remove old and install new OS in new HDD!
If not write back,ok?
Oct 16, 2007 | Acer Aspire 5100-5022 Notebook
System freezes
Acer Aspire 5002WLMi Notebook Logo
76 people viewed this question
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
