Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Problem faced by comperssor
Good evening mam
i just want to know that what are the problem faced by the refrigerator or ac compressor.........
thankyou
Why dont my compressor fill up with air.
Posted on Jan 08, 2008
  • 833 Answers
Guru, what I think you are asking is how do you know whether the compressor is good. First, you will want to get access to the back of the unit. Once you do, the compressor is the big black thing with the pipes coming out of it. Unplug your fridge for about half an hour. Clean the condenser coil of all dust and dirt. Now, look at the largest pipe coming out of the compressor. If it isn't clean, clean it off. Restart the unit. You should hear a mechanical hum. Be aware that there may be an exposed fan back there. The large pipe should be frosty. After about 5 minutes, the frost should be replaced by ice, water or be drying out. If still frosty, you are low on gas.
Posted on Dec 21, 2007
I have a 2007 chevy impala and the ac comperssor is locked up can I unplug it to make it free spen so I can drive it
It would depend on what is wrong with the compressor and if the belt is running something else. If it is running something else then you can not take the belt off with out loosing what else the belt is driving. If the compressor is the problem just switch the AC switch off on the dash and make sure you do not use the defroster, because that will engage the compressor and will lock the pulley. If the AC compressor is not the problem then you may just have replace the bearings on the clutch.
Mar 16, 2014 | Cars & Trucks
New comperssor, condenser, rec. dryer and high pressure line now power to the ac compressor. Jump the compressor and it works.
Check for update/defective-part on A/C relay(located in engine fuse/relay box), original was white, new one is baby-blue from dealer.
May 23, 2011 | Toyota Camry Cars & Trucks
Computer board went out. when you remove the computer it has a black mark behind it on the plastic housing. how long is the warranty on the comperssor of this refridgerator?
the compressor usually has 5 year warranty in fact the sealed sytem itself which includes the compressor .evap coil and usually the condenser coil has 5 years... the boards usually only have a 1 year parts warranty or up to a 5 year parts warranty but after the 1st year you are responsible for the labor on the board....the compressor though should be covered through amana for 5 years total cost... good luck to you....
Feb 16, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Moved frig a week ago and let it stand upright for 5 full days before i plugged it in... it wont cool now and dont know how long i need to run to tryn to cool, dont want to burn up comperssor??? And if oil...
If for some reason the oil didnt drain into the lines then theres nothing you can do. Once the oil mixes with freon theres no turning back. You can remove the back panel and look at your frost pattern on the coils. If you have an even frost pattern across the coils then you should be good to go. If the frost pattern is only half of the coils then you have a leak in the system or your compressor pump is damaged. It should take no more than 24 hrs to come down to temp. Hope this helps _MJ_
Mar 26, 2010 | Frigidaire FRT21P5A Top Freezer...
Compressor is damage
if your compessor is damaged than you need to replace it as because the comperssor is not repairable
Jun 20, 2009 | Refrigerators
Dodge Ram AC not blowing cold
By pass both pressure switches one at a time with small wire or a paper clip. If comperssor kicks on replace the swich that you bypassed.
if not it could be the fan clutch ot the compressor. Compressor runs about $400.00
Jun 15, 2009 | 2000 Dodge Ram 1500 Truck
MY air conditioner is not working. The compressor
Typicial if the comperssor does not turn on then you need to have the system recharged. Once there is enough freon in the system the compressor will turn on.
Jun 07, 2009 | 2004 GMC Envoy
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Ac pressure switches for 96 gmc 1500
BY PASS THE SWITCH AT THE ACUMULATOR IF WITH CAR AND A/C RUNUNG IF COMPERSSOR TURNS ON THEN YOU SYSTEM IS LOW IN REFIGERANT OR THE LOW SWICHT NOT GOOD WITH PRESUER LOW SWITCH IS NORMALLY CLOSED
Jun 01, 2008 | 1996 Chevrolet K1500
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
