Televison & Video Logo
Rachel Gagn Posted on Mar 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote doesn't wrok anymore for the volume? how can I have this function back
c20cdn
Level 2:
Sergeant:
  • Expert 167 Answers
  • Posted on Mar 10, 2015
c20cdn
Expert
Level 2:
Sergeant:
Answers
167
Questions
0
Helped
50536
Points
544
Remotes usually lose often used button functions, the only way to get it back is by replacing the remote, or if you are technically inclined, you can take it apart and clean the inside.
My Sanyo GXCC remote control only changes volume using both volume button or channel button. What do I do?
broken remote functions.. take apart and put back together. if that doesnt work. consider a universal remote with all of the same functions
I have a broksonic tv and a rca universal remote.. the remote wroks to turn the tv off and on and the volume and channel but i cant get the source button to work ?
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
http://electrohelponline.blogspot.com/
Volume control on rt2370 rca remote doesn't work.
Hi there
I would try going into VOLUME through the MENU and find volume there and set it accordingly.
good luck
Kolbrun
1helpful
Volume does not work with remote
Tries take the remote aparts,if can,some u can't they're tighten and latches from the inside.Take a rag soak it with some rubbing achahol and clean the PCB board and the inner rubbers plastics knobs on the sheet of rubber plastics that make coonntact to the PCB board.U tries take out the battery awhile and put in a brand new set of battery,remote might work for the volume button again.If not the volume control pad rubber knobe inner plastic pad that press down on the circuit board might be worn out or not making good contact anymore to the PCB circuit board.Or the remote control CPU chip are slowly shorting out the first command it take out was ur remote volume control functions.Try website like Remotes.com to buy another the tv original remote.
3answers
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
The remote does not work. My satelite remote
There is usually a remote module mounted on the inside of the front of the tv that senses the remote signal. This controls all functions of the tv. If you are not comfortable in troubleshooting this, I would recommend a repair center.
CC, SAP PIP
1) Try hard reset = unplug TV for some time,plug-in,try again.
2) Follow guide instructions carefully = one missed step is all it
takes
3) Consult owner operator manual
4) Further help? provide Model # off back of set..................T.
2answers
Volume control
Hello
If it is just not functioning for volume but do perform other functions then do open in there would be screws or can just be lock's clean the board and pad with cotton dipped into acetone if you don’t have acetone just use the dry cotton if it still doesn’t work change the remote
Good Luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
