Question about Panasonic Panafax UF-880 Plain Paper Laser Fax
Print Confirmation on UF-880
First I would like to know if there is a free manual for the Pnaafax UF-880. Also right now the problem is when we send a fax we would like to get a confirmation but dont know how to set it up.
Thank you for your assistance.
  • 284 Answers
Re: Print Confirmation on UF-880
What you are looking for is a comm journal. to turn that on you need to press function-7-4-start-1-2-start-2" it will says always"-start-stop
your finish . good luck
Posted on Nov 24, 2008
Re: Print Confirmation on UF-880 - Panasonic Panafax UF-880 Plain Paper Laser Fax Fax Machines
Select function #6 and then # 6
Posted on Apr 28, 2008
0 characters
3 Points
Hello i have a panafax uf-280m i would like to
Sometimes you can go to "print reports" then activity report and print your send report
Mar 23, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
How do you set the confirmation page
If you look on, I think, the rear cover on the top, there should be a list of procedures to follow for different setttings. If I can remember you press the FUNCTION key and then 7 for settings mode. Then scroll through using the arrow keys until you see the relevant FAX SETTINGS then you'll search for reports and so on. Once you're in the settings mode you'll see a lot of things that you can programme.
Jul 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Is it possible to get a printed confirmation report after sending a fax on a UF-790?
Yes. Fax parameter #13 allows you to automatically get a journal after 32 transactions. Go here to get complete manual free.
Apr 17, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Print out confirmation with image on page
monitor key slowly 4 times
look on the sheet for confirmation + image parameter
set with above procedure but use number 74
Feb 04, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Panafax UF-880 - volume of phone ringer
1- incoming volume press the down arrow till you want the desired level
2-outgoing volume. press monitor you will hear a dial tone. press down arrow till desired level and press monitor again your done
Dec 04, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
How to set up Time and Date?
Press Function-7-1-start and you can adjust you time and date now. any other questions feel free to ask.
May 23, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
Dec 10, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Panasonic Panafax UF-880 Plain Paper Laser Fax Logo
368 people viewed this question
Top Panasonic Fax Machines Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Michel Smith
Are you a Panasonic Fax Machine Expert? Answer questions, earn points and help others
