Question about Sharp AR-5316 Advanced Digital Imager Copier
Private When i start the copier the number 2 and the letter H are flashing on the screen and the copier dosnt oprate please...
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,346 Answers
Re: Private
Look at this link under error codes, look for copiers- sharp
Posted on Nov 15, 2007
  • 208 Answers
Re: Private
H2 is a fuser thermistor error. Most likely needing a fuser.
H4 can normally be reset doing this.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Posted on Dec 07, 2007
0 characters
3 Points
I havent received any email from Kiwibank Regarding my 2 New Bank account numbers
Please contact the bank directly. FixYa has no access to your private banking records.
Apr 11, 2013 | Olympus P-A6WPAS passport paper 013582
Touch Screen is blinking. It flashes Muratec about every 5 seconds. It was working just fine one minute then the next the screen started blinking. It wont reset, copy. I unplugged it, checked cords and...
The cause of the problem may be a couple of issues,maybe a paper jam or your printer might have run out of ink so i suggest you check if your toner is low or empty also check the paper feed assembly for any form of paper jam.
Check the screen to see if there is any code flashing as well,if there is a code,then make note of it either a number or a letter flashing and consult your printer manual for help on whta the error code means.
Jun 10, 2011 | Printers & Copiers
A letter and number appear alternately
What Letter and What number?. These usually come up as L - 1 or H - 4...both of which are easily resolved. Just let us know what code is flashing.
Feb 03, 2011 | Sharp AL 1631 Copier
Samsung SCX-4216f prints line of numbers and letters at page bo
Uninstall your printer driver.Install again your printer driver.If it problem your printer properties.Second thinks,if it problem arise heater or fuser unite please change heat roller,then fix this problem.
Feb 23, 2010 | Printers & Copiers
The letter L and then the number 1 appears when we turn on Help
My my how does this work? You will charge me to solve the problem but if I solve it myself you wish me to tell you how. Do I charge you for my solution then ? It makes no sense to me.
I solved it by the way but I'll keep it to myself thanks.
Aug 31, 2009 | Toshiba e-Studio 161 Copier Copier
When the copier is turned on the letter H and the number 4 flashes can you tell me what this means please
Hello Karen; H-4 in sharp copier it means fusing unit problem,it could be reset ,the procedure depend on the model of the machine.
Jul 13, 2009 | Sharp Printers & Copiers
Scanning and runtime errors
hi, have you tried to get an updated vista driver from the lexmark website? or if u do this fist then it is your oprating system problem.
Apr 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
Flashing symbols
Is there another part to the error code besides the 8 like a letter in front of it?
Jul 18, 2008 | Sharp AR-M205 Copier
U2 Counter sum check error When the counter check sum value stored in the EEPROM is abnormal
Enter sequence...clear, interrupt, 0, interrupt. The copier will go off. While off enter 16 and Start. Your copier will come back on. press Clear All.
may need a new cartridge as chip may be broken if this does not work
Aug 29, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
326 people viewed this question
Top Sharp Printers & Copiers Experts
George Mclaughlin
Vito Suglio
Level 1 Expert
Are you a Sharp Printer and Copier Expert? Answer questions, earn points and help others
