Question about Air Conditioners
Need schematics 10 kw electric weather king furnace
  • 86 Answers
Re: need schematics - Air Conditioners
Wht the problem
Posted on Mar 17, 2008
Re: need schematics
Water leak problem on all electrical circuit
Posted on May 17, 2008
0 characters
3 Points
Replace a kfceh3101c15 with a 20 kw. 15 kw just is not keeping up in this weather
The best answer would come from Carrier. Here is their contact info-
Feb 23, 2015 | Carrier Air Conditioners
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
How do i wire the wether king condenser model 10aja3601 to a miller furnace model m1mb056abw with a honey well pro 6ooothermostste
The condensor and evaporator must be matched. You are going to have to design your own wiring diagram to integrate all of these together. This is a tough job , unless you really understand electricity and air condition control circuitry.
Aug 04, 2011 | Weather King 10AJA3601AH Air Conditioner
What do I need to do to covert from propane to natural gas on 100,000 BTU furnace ? It is a weather king md.80PJ10ECR01
Take your Model and serial number to an HVAC parts house and they will get a kit for you that switches over from propane to natural gas. The spring in the valve is different and the orifices are different. Propane runs about 10 to, 11 inches of water where natural gas is about 2.5 to three. So if you did not change the springs and orifices you will cause the furnace to over heat and posibly catch on fire. These kits are easy to change the orifices just unscrew. The top of the gas valve has cover over the spring and an ajustment screw inside just remove that and pull out old spring and insert new one. Be careful with the springs they are very tiny and not much thicker than human hair. You really need to get someone to set the pressure for you. Feedback welcome Rus
Dec 07, 2009 | Weather King Air Conditioners
I have a weather king legacy furnace the a/c
means the compressor is directly energised may be some one tried to repair but he jumped the thermostat.
Sep 05, 2009 | Air Conditioners
Weather King Acclaim 2 Gas furnace efilters
If your furnace is easily accessed in the basement or a closet etc. then likely the filters are located either in the bloer compaertment (the small panel on the furnace) or in the ductwork attached to the furnace. There should be a removable cover. The size varies dedending on the size of your system. When you remove the old one it should be printed on it or you can measure it.
If your furnace is in the attic or a crawl space then you probably have filter grill(s) in your return air. Usually centrally located in the home.
Filters should be changed as needed depending on how you use your system but usually every 30-90 days.
Jan 17, 2009 | Weather King 12AJA4801AH Air Conditioner
Blower motor
follow the wires back from the motor to either the relay or the circuit board. normally a furnace has a board. check to see if there is any power leaving relay/board to the mtr. if it is a furnace you may need to push in the door saftey switch to get power to system. heat pump mtrs need 230 vlts furnaces 115vlts. If the power is going through to mtr properly than problem is either capacitor or mtr. capacitor can be checked for you by a local hvac supplier or buy a meter that can check it.
PLEASE rate or solution thanks. Brian S.
Nov 28, 2008 | Weather King Air Conditioners
Air Conditioners Logo
156 people viewed this question
Top Air Conditioners Experts
Mike Butler
Mike Butler
Dan Webster
Dan Webster
Are you an Air Conditioner Expert? Answer questions, earn points and help others
