When I try to on the radio appears the phrase "Code error E.
SOURCE: How do I remove the radio from a 1998 Honda CR-V?
UNSNAP PUSH-PIN FASTENERS FROM BOTTOM OF CENTER CONSOLE
AND REMOVE BOTTOM PANEL.
2. EXTRACT 4 SCREWS FROM BOTTOM EDGE OF BEZEL. EXTRACT 4
SCREWS FORM INSIDE DASH BELOW POCKET. PULL CUP HOLDER/
POCKET ASSEMBLY OUT OF DASH AND REMOVE.
3. OPEN GLOVE BOX AND REMOVE STOPPERS. EXTRACT 2 SCREWS
FROM RIGHT SIDE OF CENTER DASH BEZEL..
4. FROM BELOW STEERING WHEEL EXTRACT 2 SCREWS FROM BOTTOM
EDGE OR PANEL, UNSNAP UPPER EDGE OF PANEL, UNPLUG, AND
REMOVE.
5. UNSNAP TOP EDGE OR CENTER LOWER BEZEL, UNPLUG, AND REMOVE.
6. EXTRACT 2 SCREWS FROM SIDES OF POCKET.
7. UNSNAP RADIO/AC CONTROL DASH BEZEL, UNPLUG, AND REMOVE.
8. EXTRACT 2 SCREWS FROM EACH SIDE OF THE RADIO BRACKET
ASSEMBLY TO REMOVE RADIO FROM DASH/AC BEZEL.
SOURCE: radio error Honda Pilot code
the code should be with your owners manualy its on a card the size of a business card.there will be # s on it, make sure you follow directions in manualy on how to enter code,also you might be able to call dealer, give them your cars vin # and they sometimes will give u a code.good luck.
SOURCE: MY 2007 HONDA CRV CAR RADIO LOCKED AND IS ASKING FOR CODE
inside glove box there should be a sticker with the radio serial number and code. if that has been removed then you could try the honda owners site. you'll need the vin # and some other info
I was able to get the code recently for my 2010 CR-V
SOURCE: Hi, I bought a 2007 Honda Ridgeline The radio
you can call honda if it is the factory radio.. if you give them the vin number they should be able to help you... once you receive it you should keep it saved somewhere because every time you disconnect the battery it will reset again... sometimes you can find the code in the owners manual or sometimes you get a little card with the code on it... good luck
SOURCE: 2008 honda accord stereo code error 4
I just changed the battery in my 08 accord same thing there is a code on the left side of glove box.type that code in using the preset numbers it will be on white sticker
