Refrigerators Logo
Wanda Gray Posted on Mar 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get a samsung manuel for refrigerator rfg298hdbp
I need problem solving and answers. Display screen shows OF OF
ka4iup
Level 3:
  • Samsung Master 4,062 Answers
  • Posted on Mar 09, 2015
ka4iup
Samsung Master
Level 3:
Answers
4062
Questions
0
Helped
1096689
Points
51404
How to remove water filter housing
2 way
one just by unscrewing it.
second its a bayonet fitting like a light bulb. push and turn.
Have a samsung refrigerator model rfg298hdbp/xaa that is flashing 33e
The heater on your ice fill tube is not working it needs to be replaced
Samsung s3500i black display
change the strip of your phone are change the display your problem can be solved
1helpful
Freezer is set on -2 degrees, actual temp in freezer is -20. What sensor is causing this problem
I suspect that you do not have a problem. . The standard operating temperature of a freezer is around -20 degrees CENTIGRADE (-2 Farenheit)
Your freezer has an option to display degrees C and degrees F, I suspect it is showing farenheit
I have taken a look at a copy of the manual, which can be found at:
http://www.manualowl.com/m/Samsung/RF217ABBP/Manual/142915
But for the life of me, I can't see how to change the display from C to F and back anywhere in the guide. If I am right, swapping the display back to Farenheit will solve the display issue.
If you are unable to change the display, you can try calling Samsung in arlington NJ on 1-800-726-7864.
Hope this helps. Please add a comment to this thread to let me know if the problem is solved or if you need more help
7helpful
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
2answers
Touch screen menu not working
hi
the display gets affected. format your phone and try it . if still having problem change your display screen in your mobile.. the touch sensor may be affected in your phone. dont try to do it yourself. its great risk. contact your service provider to change the display screen. if your problem solved after changing the display . vote for this answer. im sure the problem will be solved after changing the display screen of your mobile
thank you
Samsung j700
I have a j700 with image problem the display show all messy like ribbon problem, but i already test with 3 ribbons and the problem not solved, change display and the problem is 100% board.
Any solution for this?
Thanx
Arshad Ali Magsi
2helpful
2answers
Display is showing L
I had the same problem. I do have the manuel which does not state what the codes are. I called the help line and they said it was a low battery. I hope this helps you.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
