Question about Sony KV-35S65 35" TV
Works fine 30 minutes then no picture
Hi , I had no power at all. So I replaced the IC601- MX0841 , R607 - 0.01 ohm resistor, Q502 - C5148, and flyback. When I powered up everthing was great for the first 30 minutes then the picture went out but the sound was still working. I unplugged it and plugged it back in. The picture came back and stayed for about 10 minutes then went out again. I resoldered the driver transfromer and most everthing else on both boards
It will stay on for about 30 minutes from a cold start and 10 minutes when warm. Any Ideas?
  • 1 more comment
  • pyrotech Dec 20, 2007
    Hi, Is there any way I can test the crt?
  • pyrotech Dec 21, 2007
    Thank you very much. Merry Christmas and a Happy New Year.
    Thanks,
    Pyrotech
    Genius:
  • 1,694 Answers
Q502 must be top-shelf , first-quality only = no generic.
Use RCA 237470 or Sony 8-729-035-75 Both are first quality,
but RCA much less expensive..............................T.
Please rate this solution......................
Note:Blow-up caused by bad connects in horizontal driver
circuitry.Therefore,save your good,used flyback!
Posted on Nov 13, 2007
  • Vista Electronics Nov 17, 2007
    After further consideration, the reason your pix blanks out is
    a bad CRT......common on S and V line Sony.........T.
  • Vista Electronics Dec 20, 2007
    Yes...with a CR-70 Sencore CRT checker available at most
    older,established TV repair shops....most will charge a fee...T.
KV-32s66 Flashing stby timer LED- no pic no sound
check for any short circuit on the board.
Oct 07, 2008 | Sony KV-32S66 32" TV
TV won't power up after surge
Try this: unplug the set and wait about 10 or 20 minutes. This is to make sure that the main power supply filter caps completely discharge. Look on the power supply board, close to where the AC cord attaches to the board. Look for a white resistor labeled "0.1 OHM" (the symbol for OHM, like an upside-down U) and measure it with your ohm meter. If it is open then your switching transistors in the main power supply are most certainly shorted. Older sets had 2 separate transistors on little heat sinks labeled "C4834", then they switched to 2 transistors in one package labeled "MX0841" or "MX0842", and then some sets went to two separate MOSFET transistors. Measure those parts and post your results and we will guide you from there.
Aug 08, 2007 | Sony KV-35S42 35" TV
Sony KV-35S42 35" keep blowing MX0841 and .1 fuse resistor
Normalmente cuando falla la fuente se dañan los transistores convertidores, la resistencia 607 de 0.1 ohmios los condensadores C609, C610 de 0.47 mf. C611, C612 de 0.22 mf.
En nuestro caso basto con cambiar el MX0841 y R607, ya que el daño se debió a una sobrecorriente provocada por la salida horizontal, esta fuente e mas robusta que la de otros modelos ya que accidentalmente se provoco un corto en la salida del B+134 y simplemente solo se daño el MX0841 y la resistencia R607, se cambiaron y la fuente volvió a funcionar perfecto
Oct 28, 2008 | Sony KV-35S42 35" TV
KV27S42 dead - 4 blinks
the +13 and -13 are generated by the flyback transformer as well as the 200 volts. the 135 is your B+ voltage and sould be there at start up. check the HOT and the Flyback. if there is no 135v check IC1751 on the C board sometimes if bad it loads down the 135v line. and can give a faulse vertical error.
Apr 02, 2008 | Sony KV-27V42 27" TV
Sony KV-35S66
Check and replace,IC601, Q502, R607.
Billy
Jan 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, sound works on Sony TV
Hello, maybe there is a contact error in power supply or the deflection stage. If the resoldering does not help- here are some possible solutions: remedy Replace flyback location LP04. Entered for KV32S22 /SONY (Chassis) remedy 2 Replace IC351, Q602, Q601 (2SC4834M), R607 (1R/0.5W), R622 (10R), IC641 (SI3090CA) and Q502 (2SC5148). remedy 3 Replace tuner. remedy 4 Replace R607, Q502 and IC601. Entered for KV32S22 /SONY (Chassis) remedy 5 Replace regulator IC, R607, check C609, C610 (0.68pF) and C613 (0.0022pF/500V). remedy 6 Replace horizontal output transistor (2SC5148), IC601 (MX0841) and R607 (0.1R). remedy 7 Replace IC1701 and IC601. remedy 8 Replace Q501 (2SC5148), R607 and resolder horizontal driver transformer. remedy 9 Check and replace horizontal output transistor Q502 (2SC5148) and IC601 (MXD8411AB-F). remedy 10 Replace shorted R607. Also check T501 and Q501 for dry joints. remedy 11 Replace C608. remedy 12 Replace Q602 and D648. remedy 13 Replace Q502, Q601, Q602 and R602. Entered for KV32S22 /SONY (Chassis) remedy 14 Replace D626 (6.2V). remedy 15 Replace IC801 and R607. remedy 16 Replace horizontal output transistor and the associated damping capacitor. Check flyback transformer and SMD microprocessor as well. remedy 17 Replace R639 (4.7R/0.250W) located on G board in standby power circuit. remedy 18 Replace D600. remedy 19 Replace C502 (0.47uF/50V). remedy 20 Check D655(1N4937), D657 (1S1834) and Q601 (2SC4423). remedy 21 Check D606 for leakage. remedy 22 Check yoke between vertical and horizontal windings for S/C. remedy 23 Replace Q601 (2SC4834MNP), R607 (0.1R) and C517 (2.2uF/250V). remedy 24 Replace R611.
Apr 22, 2007 | Sony KV-27V22 TV
Clicks - but no picture!
According to the manual... Problem: 'a red light keeps flashing on the tv for more than a few seconds', What it could be: 'your tv may need service', What you can do: 'Call your local Sony Service center'
Nov 29, 2006 | Sony KV-27S45 27" TV
Sony KV-35S65 35" TV Logo
166 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
