Question about Canon PowerShot A95 Digital Camera
Color/hue I get pink color / hue when i shoot in daylight and the picture is absolutely unclear but the problem resolves in night / indoors. can it be white balance problem ? doesn't seem to be, as even after correcting AWB ,  it doesn't work.
    Champion:
  • 206 Answers
I see this everyday. The problem is faulty CCD sensor ( see enclosed pic ). You are lucky because Canon will replace the sensor free of charge so contact your agent.color/hue - 79c5c87.jpg
Posted on Nov 13, 2007
  • Canon Master
  • 4,738 Answers
As mentioned, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your cameras warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 16, 2007
Image has lines and pink in colour
This maybe two problems, the pink color hue in the picture and lines from lens shutter problems. Your LCD is still good. You have to replace motherboard and lens.
Feb 07, 2012 | Canon PowerShot A95 Digital Camera
My pictures have a purple tint to them
You're either using old/expired film, or taking photos during dusk. Color film is balanced for daylight photography. Using it under conditions other than that will result in varying color casts on the resulting images.
Fluorescent lighting: Greenish
Indoor bulbs: Reddish/orange
Outdoor at night/dusk: Blueish/purpla
Ourdoor at dawn: Pink/blue
Or, you may have just gotten bad print work done. Try a different lab.
Jun 12, 2011 | Canon EOS-AE-1 35mm SLR Camera
Indoor photos are yellow.
Your camera is choosing (or you chose) the wrong white balance setting. Try Auto White Balance, and if that doesn't work, try tungsten white balance. You could switch to daylight color bulbs in your lamps.
May 02, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
My indoor photos all have a greeninsh yellow effect
That's caused by lighting. More specifically by the type of lighting in use there. Every different type of light puts out a certain color range, some pink, some green, some yellow, some bluish.
How do you fix it?
1. use flash. Flash puts out a bluish light color balanced for daylight. Most film available today is color balanced for daylight. Problem here is that on camera flashes are weak and only reach about 10 feet. The rest of the picture will be greenish yellow. More powerful flashes extend that 10 feet based on the power they have, and may provide enough coverage. The reach of the flash is also determined by the film ASA.
2. use a filter on the lens. Get an FLD (flourescent-daylight) filter.
3. Scan the negs to digital and correct with Photoshop or another photo editing program.
Jan 24, 2010 | Fuji Photography
What iso of film im going to use...?
For outdoor pictures in daylight, I'd suggest ISO 200 film. Indoors, you may have to go to 400 or even 800.
There certainly is nothing wrong with Kodak films. If you're shooting slides, you might want to give the Fuji films a try, they tend to give much more saturated colors.
Jan 12, 2010 | Contax T2 35mm Point and Shoot Camera
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
My gs500s colors are bright pink and i tried changing white balance and nothing works
Try going into "reset" master mode. otherwise you need to make sure your camera is shooting on the right setting for the light you are using. For example, when shooting in daylight with interior light setting (approx. 3200k) your photos will look off color and yellow or pink because sunlight is 5600k approx.,. . . contrary while shooting indoors with incandescant lighting if the camera is set for sunlight exposure (5600k) the picture will look blue. Make sure you read the manual on how to white balace, but first take the camera out of AutoExposure settings to do all the settings manually. Auto focus and auto exposure are for rookies and these types of errors will happen. Always try to do manual iris and manual focus for best results zoom in and get your focus on the subjects eyes then zoom out and frame up your shot.
Aug 03, 2009 | Panasonic PV-GS500 Camcorder
Olympus mju850 - fine at night but hugely overexposed in daylight
it is ur luck if camera still works in indoor pics then only take indoor pics but the pics are not crisp and clear they need to be there will be dis colored and scratchy but u can try see which are better i think pics without flash with adequate light will be better one's
i am here to help u in this if u like
Apr 08, 2009 | Olympus mju 740 Digital Camera
Best situation to use each of the shooting modes
Program Auto (Factory default setting) Program Auto mode is used for regular photography. The camera automatically makes the settings for natural color balance. Other functions, such as the flash mode and metering, can be adjusted manually. Portrait Portrait mode is suitable for taking a portrait-style picture of a person. The camera automatically sets the optimal shooting conditions. Landscape + Portrait Landscape + Portrait mode is suitable for taking photos which include both your subject and the landscape. The camera automatically sets the optimal shooting conditions. Landscape Landscape mode is suitable for taking pictures of landscapes and other outdoor scenes. The camera automatically sets the optimal shooting conditions. Night scene Night scene mode is suitable for shooting pictures in the evening or at night. The camera sets a slower shutter speed than is used in normal shooting. If you take a picture of a street at night in any other mode, the lack of brightness will result in a dark picture with only dots of light showing. In this mode, the true appearance of the street is captured. The camera automatically sets the optimal shooting conditions. If you use the flash, you can take pictures of both your subject and the night background. Indoor Indoor mode enables you to take pictures while indoors by allowing the flash to reach farther away. Beach & Snow Beach & Snow mode enables you to take pictures of scenery containing white sand or snow. Cuisine Cuisine mode enables you to take pictures of food by increasing the saturation, sharpness and contrast settings to take sharp, vivid pictures of the subject. Self-portrait Self-portrait mode enables you to take a picture of yourself while holding the camera. Point the lens towards yourself, and the focus will be locked on you. The camera automatically sets the optimal shooting conditions. The zoom is fixed in the wide position and cannot be changed. QuickTime Movie QuickTime Movie mode lets you record movies with sound. The focus and zoom are locked. If the distance to the subject changes, the focus may be compromised.
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
Canon PowerShot A95 Digital Camera Logo
176 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
