Cylinder head replacement
SOURCE: what torque spec for chev aveo 2004 cylinder head
18 lb ft+60°+60°+60°+10°
NEW HEAD BOLTS ARE REQUIRED WHEN REPLACING THE HEAD OR HEAD GASKET.
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
SOURCE: need cylinder head gasket torque specs.
looks like there is special sequence to reassemble and tightening, a quick note replace any bolts that have two punch marks.tighten as follows: x x x x x 10 4 2 6 8 x x x x x 7 5 1 3 9 torque all down to 15 ft lbs torque to 30 ft lbs plus 90 degrees. Good luck!
SOURCE: torque specs for 2004 kia rio cylinder head
youre going to torque it to 65 ft lbs.. start from the centre out and go diagonally. be sure to replace the head bolts and very lightly oil them before installation.
SOURCE: head bolt torque specs for 200 honda accord 3.0
its a three step process 1st 29ft/lbs 2nd 51ft/lbs 3rd 72.3ft/lbs
what spec u need??
