Question about HP Deskjet 840 InkJet Printer
HP Deskjet 840
I had a problem with HP Deskjet 840 printer. printer is initialising, but doesnt pick up the paper.Head is moving ideal(left to right), but the print is not coming.
  • maracece Aug 04, 2008
    hola
    Mi impresora que hace años que uso sin problemas, comenzo a atorar el papel y a hacer ruidos extraños cudno empieza a funcionar.
    Me pueden ayudar???
    Cristina de Montevideo. Uruguay
  • Anonymous Dec 25, 2008
    I can not to print only write print failed
    I dont know whats about that
Hola estan hay para aserle una pregunta
Posted on Jul 19, 2008
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
My printer is printing blurry on the right hand third of the page - the rest is crystal clear
The printer's head with the ink cartridges runs on a rail above the paper path. The paper comes out face down so the left side of the printer prints the right side of the page. The bottom of the print cartridge is either too close or too far away from the paper. So look for something that is lifting the paper up like some paper wrapped around the rollers or something that would move the head up or down like a loose rail - it would be on the left side of the printer. If it is not paper or some other foreign material on the rollers or stuffed behind them (open the rear cover plate too), the chances are that it will not be cost effective to service the printer.
Nov 11, 2010 | HP DeskJet 810c InkJet Printer
The green light on my HP Deskjet 3845 is flashing ..when I try to print it tells me there is a paper jam ..there is no paper jam. I have inspected the printer carefully, reloaded the paper. It will not...
i think u should check for peices of paper ,tiny objects etc that might be obstructing the movement of the paper. also check that the print head is not disconnected from the belt you can check this by slidind the print head from side to side and ensure that both of them are moving hope this helps.
Oct 19, 2010 | HP Deskjet 3845 InkJet Printer
HP Deskjet 1200c will not feed paper. Fails to pick up paper from tray. If force pickup by hand can get it to start printing but moves paper in wrong direction as as positions for printing. Does not...
This sounds like a problem with the paper pick up rollers. I would suggest cleaning the rollers with a little isopropyl alcohol. Please make sure the machine is turned off when doing the cleaning. Let the rollers dry for a few minutes. If this does not work, The rollers would probably have to be replaced.
Aug 28, 2009 | HP DeskJet 1200c InkJet Printer
My HP Deskjet 6940 won't print.
Your Printer is Malfunctioning. Contact the HP Service Support for servicing of your Printer.
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
The ink well is full and leaking. How do I clean it out.
There is an ink well below the home run position of the print head and cartridge assembly. If you open the lid of the printer, the print head moves to the center of the rail. You then unplug the printer and gently move the print head to the left and out of the way. If you shine a flashlight in the right hand corner or home run position, you will see the ink well. You can clean it out with a paper towel or a syringe. Obviously, the well is no longer overflowing and the drip should stop.
Apr 08, 2009 | HP DeskJet 1220c InkJet Printer
Printer cannot print.
HP Deskjet 1125c printer - Printer does not print. Bottom orange light keeps brinking. Paper cannot not even be picked up by the printer.
Jan 17, 2009 | HP DeskJet 1125c InkJet Printer
Printing
It almost sounds as if the guide on the left side has been moved. Reload the paper so it is up against the right side of the paper tray and then move the left guide up against the paper.
Judy F.
Aug 28, 2008 | HP DeskJet 6122 InkJet Printer
Won't pick up the paper but the cartridges move up and down the line
Hai Boss it is not the problem with the Catridge . Some of the Spring has begin missing in assemble part . you pull the paper out the problem cause from there never ever pull the paper ..
Feb 12, 2008 | HP DeskJet 970cse InkJet Printer
HP Deskjet 840 InkJet Printer Logo
106 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
