Chain saw brake on husquvarna model 41
To replace the brake band do as follows, remove the bar nuts and take the brake away from the saw, engae the brake to remove as much tention off the internall spring by pushing the hand guard fully forward, remove the allen screw securing the hand guard, do not remove the e clip and pin from the hand guard, tap out the pivot collers and remove the hand guard, remove the cross head screws securing the spring cover, carefully remove the spring from under neath, tap out the silver pivot pin from the knee link activating arm, use a puch from the other side of the brake to remove the roll pin securing the other end of the band, with the band out remove the screw securing the band to the knee link, install the knee link to a new brake band, re fit the roll pin in the band and re fit into the cover, insert the spring, this will have to be compressed to get it back in, re fit the spring cover, you need now to load the brake, fit the hand guard onto the cover, insert a conical puch through the hand guard and cover to enable you to pivot the hand guard back and load the brake, now fit the hand guard properly onto the cover and re fit the collors and screws.
