Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
TV Turns off and on
Our TV works for several hours and then turns itself off. A couple of minutes later, it turns itself back on again. Then it goes through the on/off process several times within a short timespan (a few minutes on, a few minutes off). We turn off the TV let it cool down. Turn it on and it is good for another several hours.
Could it be a fuse? If so, can we fix or do we have to call a repairman?
  • 22 Answers
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Posted on Nov 13, 2007
  • Michael Ahlf Nov 13, 2007
    Rated "thanks for trying"???
    Look, this is a 2003 model known to have bulb problems. Sony indicates an "average" 1-year replacement for the bulb on normal usage.
    If you've had it for a couple years of normal usage without a bulb replacement, you've been lucky.
I had this problem replaced tghe bulb and it works fine.
Posted on May 05, 2008
Sony 42 inch plazma display on screen problem powering down
if the fans are stopping you will need to replace them
Apr 29, 2014 | Televison & Video
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
I have a Epson emp7900 and it comes on and works great "Picture and sound" for about five minutes then it turns itself off?
Tries tv unplug,replug it back like about an hour later for the tv resetting itself back to the factory setting.The tv now should be working again.If the tv still have the same problems,mean the tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like, to buy a whole new refurbish the tv power supply board for the replacement.
Sep 21, 2011 | Televison & Video
Bush tv frequently turning itself off
make sure you have not accidentaly scheduled a power off and on if yes torn off/disable them if not check that your power cable is secure
Dec 21, 2009 | Televison & Video
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
May 09, 2009 | Sony KDS-60A2000 60" HDTV
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Turns itself on
if it does this again then you will need to replace the cpu unit or main control board
Apr 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
RCA Colortrak plus. Model# F32672SB Serial # 807560570 Chassis # CTC187CJ3 Manufacture Date Feb 1998 Service # F32672SBFM3 4/21/08- TV worked fine last night. This morning worked for about an hour. ...
It's probably a cracked solder joint in the power supply / horizonal drive stages. As the unit heats up the joint is seperating and breaking connection. It could also be a component failing when it gets hot. Usually the voltage regulator or Horizonal Output Transistor (both mount to heat sinks).
If you know how to solder and want to tinker, unplug the set for a couple days (to let the power capacitors discharge) and resolder and crystalized it cracked joints on the board(s) where the power stages, and flyback transformer are located.
If you decide to operate the set with the back off, please be careful. The high voltage on a TV can be 30,000+ volts.
Hope that helps,
Apr 21, 2008 | Televison & Video
Samsung 1080p turns itself off
Probably a bad Inverter board. I have a Dell 32" LCD TV but it has a Samsung Panel inside, found a burnt transformer on the inverter board, Still trying to find a replacement.
My TV comes on for a second then goes black, power still shows on but no picture. 1.5 years old
If you are not a tech person, take it in for service.
Dec 27, 2007 | Samsung HL-R5678W 56" Television
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
159 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
