-   three red lights blink and my screen is black-   chiquinarco
Nov 22, 2007
-   e74 customer support required on scene in a nutshell.
bottom quater red light flashes.
tried booting system with and without hard drive connected,all cables checked and correct.
i keep the power supply disconnected when not in use,can't be overheating.
It was one of the first consoles out.
Help?-   madralph
hey i had this same problem with mine
its to do with the graphics chip and av port but i got it fixed.
the easyest way is to call microsoft but that takes time. the other way i fixed it was to wrap it in two towels. it worked for me.
ok first thing to do is take everything out ur xbox e.g hardrive controllers etc only leave the av cable and power cable.
2nd lie a towel on the floor and sit the xbox on its side on the towel turn the xbox on till the error message plays on ur tv and then wrap the towel around the xbox blocking all the vents, put another towel over it to make sure the vents are covered. leave on for 15 mins in the towels then after 15 mins remove the towels and turn off xbox leave for 5 mins then turn on and it should work it worked for mine. its only a temp fix but at least you can play it while your waiting on microsoft
You have xenon version and it lasted , if it's under warranty by all means send it in . A note about the towel trick 200 deg can damage the capacitors inside the unit and kill the the thermostat in the C.P.U- G.P.U ,which will give two red Over heating , They are very Fixable provided they are not abused .
when i download songs for rock band 2 it completes the download and when im playing in the middle of...
(More)
when i download songs for rock band 2 it completes the download and when im playing in the middle of the song it tells me that the song data is not there and kicks me out to the main menu
I cant play original xbox games on my 360 i have a 250 gb hard drive. the game shows up but when i...
(More)
I cant play original xbox games on my 360 i have a 250 gb hard drive. the game shows up but when i try to play it gose to a screen that says error. i have down loaded all backward compatible software.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
