Unscrew your Laptop HardDrive bay and remove your harddisk first, then try to boot your system wthout the Harddisk inside. If it Boots past the HP Invent Logo Page, then your harddisk is the one that is faulty, if still doesnt, get another good, working RAM, apart from the one in your system, and use it to test your laptop...making sure that the harddisk is still not inside...then if it boots insert your Harddisk back with the new RAM, and restart your system.
If in the first case it boots (i.e wihout the harddisk inside)...then it means your harddrive is faulty, just retrieve your file on it and get a new one.
If in the second case it works (i.e with a new external RAM) then just change your RAM instead.
Hi mohamed04,
I recommend you to perform an HDD self test so we can understand if you have a faulty HDD or just a Software problem caused by any windows update or virus that might have corrupted your windows boot file.
For performing an HDD self test you should turn on the unit and when HP invent logo appears press " ESC " key, then you will have access to other menu where you should select option " F2 - System Diagnostics" and then " F4 - Hard disk Test" . After process finishes it will provide you a message with " success" or #xx Fail".
You need a new hard drive and install fresh windows operating system. Maybe after that you can try to put your old hard drive to external enclosure hard drive and try to recover your computer will recognize the hard drive. Hope this helps,
HRH
