Cameras Logo
K
Ken Allen Posted on Mar 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have three jpeg (photos) that have to be reduced in size so as they can be used in a Gumtree add. Can somebody please put me on the right path.
bzet1820
Level 3:
  • Master 700 Answers
  • Posted on Mar 09, 2015
bzet1820
Master
Level 3:
Answers
700
Questions
Helped
211682
Points
2147
Just search in google:
"howto resize .jpg free"
you will have several thousand programs which will let you do that. if you have installed any picture viewer, it most probably have already resizing capability in it. search usually in edit section.
Have had problems uploading photos to walmart and private messages on face book since I hooked it up.
The pictures are too big, reduce the size by compressing them using JPEG software.
Change the file format when saving can reduce the file size by up to 90%.
1helpful
Uploading photos
How do i troubleshoot gigaware 8' digital photo frame? it will only read one photo off the SDHC card 16gb that i put into it. i can read the card on my computor.
Some picture display frames will only handle files below a certain size and of certain types. Check your manual for the gigaware to see what those restrictions are. It may be that you will have to reduce the resolution or size of the photos or make sure they are all jpeg.
Oct 19, 2014 • Cameras
How do i get a picture the right size to fit on my social media page?
if you have a photo in jpeg format then it is possible to save it in jpeg format too but changing the parameter "JPEG quality factor" from 100% to 80% for example. The pixels of photo will be the same but the size smaller. I usually use Microsoft Photo Editor application on my Windows PC:
1- open file
2- save as ...
3- choose jpeg format
4- press button "more"
5- change jpeg quality factor %
6- press save
Bye
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
I received a GE model no. 27956FE1-A as a gift over a year ago. I put some pictures on the digital picture frame then. Now that I want to add some, I get a message that the pictures are not compatible. ...
I have discovered the problem
There is two things. First that the memory card used cannot be more than 2 GB and second that each image file cannot be larger than 2 MB. My photos where much larger than this and I discovered in the manual that it "hints" to pictures being 2 MB in size, I re-sized my pictures and no longer received this error. hope this helps.
How do you reduce the size of images already taken
There are three options
Print the photo in smaller size you want
Reduce the size of the photo with the camera settings
or upload the photo to the computer and save it as a jpeg picture with any photo editing programme.
How to reduced photo in format (JPEG)
To decrease the size of the image as well as change the format to jpeg, Open the file in PaintBrush and do a "Save As" and choose the file type as JPEG, and the size is reduced.
Once the size of the file is small, it won't take much time to upload in any site.
1helpful
2answers
Jpeg wont add to contact
hi,
just find a suitable software and resize your photos to 480x320 before downloading to phone. it seems prada can only support small size pics when added to contacts.
2answers
Vido files to big to send e-mail
downlaod winzip and send the file thou it.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
