Cars & Trucks Master
- Posted on Mar 09, 2015
Re: peeling paint on cinderblock walls in basement
Just a guess, but it is likely that moisture is causing the paint to peel. I suggest you remove as much peeling as you can with a wire brush and then use a waterproof sealant. I had very good luck with a product they sell to seal cement walls in basements with moisture problems.
Dave, great question regarding your paint peeling off your cinder-block walls in the basement. Have you talked with a contractor who specializes in waterproofing? It seems like it could be an issue of needing to waterproof the basement. It could also stem from humidity (or lack of it). Getting a professional to check it out may be worth your time. Good luck, I hope everything turns out OK. http://www.reliablebasement.com
