Back to:
Tags:
HP Photosmart 2575 All-In-One InkJet Printer
COLOUR CARTRIDGE (by 4 users)
posted by GEMZIE on Nov 13, 2007
Put in a new hp original cart 2 weeks ago if that, printed out a pic fine. came to print last nite and coming up with the following msg - remove and check colour cartridge, this msg wont go away and wont let you do anything.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Jul 26, 2008
Same problem here with it saying to remove and check the color cartridge. Still not working after doing that!!
Comment by Guest, posted on May 21, 2008
Same problem HP Photosmart 2575 "remove and check colour cartridge" tried all the steps recommended by HP...no good!
Comment by Guest, posted on Jan 01, 2008
i recently changed the colour cartridge the printer worked fine until 3 days ago when i turned it on and then an error message appears saying "Remove and check color cartridge"
Can you Help with these Printers problems?
HP Photosmart 2575 All-In-One InkJet...
printer has ink and is hooked up but will not print data
My scanner was working fine yesterday i tryed to scan...
not printing.on screen instructions remove and check...
Have replaced new color cartridges which are HP...
When I use the 2575xi All in One to copy a sheet it puts a...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
