Question about AOC CT720G 17" CRT Monitor
AOC 5En monitor
R449 and R460 badly burned cannot distinguish value of the resistor
  • 2 more comments
  • Anonymous Nov 16, 2007
    hi,
    i have an AOC 5En crt monitor. it went wobble since few days ago and even can't display in maximum size. does anyone know how to fix it? thank you.
    eko
    esetianto at gmail dot com
  • Anonymous Jul 23, 2008
    hi,
    i have a monitor here aoc 17" black, i hang already flyback the light emitting diode blinker. what is the trouble?
    thanks.
    jiber of bacolod city, phils.
  • john carlo Aug 18, 2008
    While i was using the computer the monitor screen just turned black.
    It is still switched on but it doesn't display anything on the screen.
    And i can hear ticking noise on it. It guess it was due to Q901 transistor.
    But i still didn't do anything, except take a look on the inside of the monitor
    searching if there is any components that smelled burned.
  • galahan11 Feb 16, 2009
    but on the next day i used it goes back to normal, but after an hour of using it, it will go black again
I have a problem also with my AOC 5en monitor, sometimes the display will be distorted but if you try to slap the upper back of the monitor, it goes back to normal then after few minutes, the problem comes back again... thanks...
Posted on Sep 17, 2009
Check Horizontal circuit, it's the main problem of this monitor
Posted on Jan 08, 2009
  • 4 Answers
Open the monitor and check for cold solder and broken solder then re-solder it, you can find more of it just by looking for the brown colored pcb (pcb turned brown due to heat generated by parts soldered to it such as power transistors, power ICs).And look for the 5 pin IC then re-solder its pins. Prolong use of such monitors with that kind of problem can damaged the horizontal output transistor. So fix it first.
Posted on Jul 11, 2008
Replace new moitor....
Posted on Nov 15, 2007
My Monitor turns off and on. I can here the relay
I think it's the refresh rate.
In XP:
Right-click, properties on the desktop
Select settings tab
Hit the advanced button
Select the monitor tab
hit the box (hide modes that this monitor cannot display)
Select a new screen refresh rate
hit ok twice.
Feb 05, 2010 | AOC 5 En 15" CRT Monitor
Need schematic diagram for AOC 5 En model (white 15 inches color monitor) - thank's
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
Nov 21, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor 15in. 5En model. during power on all led lights functioned and no display was observed
u try to reorient ur vga connection it might be a loose connection between ur monitor and ur cpu otherwise ur vga cable is defective...
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
My AOC 5en CRT monitor have a horizontal line whole screen... how i fixed it?
this is called hline problem. only a thin line is seen in the screen and the screen is black. the cabinet needs to be opened then it needs slight setting from the picture tube to get the whole picture.
Sep 05, 2009 | AOC CT720G 17" CRT Monitor
I Want to know ,what is the code of R939
Try this:
http://www.eserviceinfo.com/downloadsm/35768/AOC_CT700g.html
Aug 09, 2009 | AOC CT700G 17" CRT Monitor
No power dead set 5en aoc monitor
just try to change the horizontal transistor C5386 or CXXXX... with a new one....
Feb 22, 2009 | AOC 5 En 15" CRT Monitor
Burned resistor... no clue what is its value
brYze,
take a look and get the resistor number printed on the pcb. i might be able to give you what you're asking for.
Francis
Aug 31, 2008 | AOC 4 Vn 14" CRT Monitor
AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
Aug 06, 2008 | AOC 5 En 15" CRT Monitor
Having a form of glasshour display
yes i have repaired my AOC 5En 15" CRT monitor diode # Diode 406 or check IC401,Q404,Q405,Q406 or visit my site for symatic diagram
Jul 12, 2008 | AOC 5 En 15" CRT Monitor
AOC CT720G 17" CRT Monitor Logo
255 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
