Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
A
Anonymous Posted on Mar 08, 2015
How do i unlock the door as it will not open - Hotpoint Aquarius WD640 Front Load Washer/Dryer
nomess
Level 2:
  • Expert 343 Answers
  • Posted on Mar 08, 2015
nomess
Expert
Level 2:
Answers
343
Questions
Helped
101408
Points
753
As you know, the door is locked while the machine is working.
The most likely cause of your problem is that the 'interlock' has malfunctioned and needs to be replaced.
The problem is to get the door open.
Try to remember which way the latch hooks into the interlock.
It may be that a flexible kitchen knife slid behind the door can release the doorlock, or a length of thin strong string passed around the door and pulled towards the hinge side will release the latch.
N.B. Be careful not to damage the seal....!
If these actions don't work it would be best to call a technician to release the interlock from the inside of the machine and replace the interlock, which can be a slightly complicated job..
Good luck.
Nomess
How do i unlock the door as it will not open - 25537329-anftw1jgfiko3zgcdjsn1gcm-3-0.jpg
Doors not opening even if they are unlocked
My 2009 Sebring does the same thing occasionally but only the drivers door gets stuck (dead locked - even though the locks appear to pop up).
The solution I have found once this happens is:
1) The car needs to be driven (crawl in thru the passenger door) -even just a short distance
2) Engine shut off & doors locked with remote (after you've exited from the passenger door of course)
3) Leave turned off for 10 minutes
4) Doors will now open when unlocked with the remote
I have a 1996 gmc suburban that i cannot unlock the driver's door. it was locked with key fob. i cannot unlock the door or open the door. the key will not unlock the door. help anyone?
if the key does not turn the lock spray it out with wd 40 run key in and out of lock few times.because everyone uses remotes to open their cars the waffers in the door locks get coroded and wont fall in proper place when key is inserted.give it good cleaning and see if it will unlock
My doors unlock wit key but i cannot open either of my front doors ...how can i unlock my other doors to get in?
front doors will lock & unlock with key but they wont open with the door handles on both doors .are you sure they are unlocking?
1helpful
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
4helpful
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Un work of the doors auto control lexus
4. Shut door.
5. Open door.
10. Close the door.
11. Open the door.
13. Close the door
Long beep to follow if successful.
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
1helpful
Drivers power lock will not unlock with remote.
the door lock actuator is defective, they get really hard to move when they go bad, that is why the difficulty with the key.
2000 Grand Am SE 4-Door
This is only a possible solution to your problem. I had similar problem with my car. It turned out that the window locking toggle on the driver door not only prevented the other windows from being opened by passengers but also controlled the door locks. When I unlocked the window control I was able to unlock the door. Another possibility is the armature inside the door has come off the locking mechanism.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
