To remove the glass globe on a 70" Casa Vieja Coastline Modern Contemporary fan, you need to follow these steps:
Turn off the fan and wait for the blades to stop moving.
Locate the screws that hold the glass globe in place. These screws are usually located at the base of the globe.
Use a screwdriver to loosen the screws. You may need to turn them counterclockwise to loosen them.
Once the screws are loose, gently pull down on the globe to remove it from the fan.
If you have any trouble removing the globe, please refer to your user manual or contact Casa Vieja customer support for assistance.
sometimes the heat fuses it put on a pair o' oven gloves and untwist the bulb until it comes away from the fitting (make sure it's turned off) then get a pair o' pliers and remove end cap!
Hampton Bay assembly information is tough to come by on the internet - except for sales info. As an electrician, I have hung more fans than I can remember, and have never found any that were not secured by either (1) three or more thumb screws, (2) a threaded portion of the glass globe or (3) a "bayonnette" (quick twist) type mount that required little more than an inch or so of twist to remove.
The globe should be removed by either loosening / removing three or more thumb screws that are designed to engage the recess between the globe itself and a lip around the opening; unscrewing the glass globe light a light bulb ; OR by twisting the globe about an inch or so in one direction or the other (like many automotive-type lamps). I suspect the type you have is the latter. From your account of what is happening, it suggests to me that the entire fan / light fixture is twisting on the fan support on the electrical ceiling box when you are trying to twist the globe. The globe and rest of the fixture are moving as one instead of independantly of each other.
If yours is the type that must be twisted from the base, you'll need to prevent the rest of the fixture from twisting at the same time while attempting to remove the globe. This will probably require a second person to help - given that it seems to have become wedged in place, and trying to grip it and balance the globe might be to much to do by yourself. If yours is held in place by thumb screws, no amount of twisting will allow it to be removed.
There should be no "secret" way of accessing the light bulbs, something has happened that is preventing the easy removal of the globe - whether it is corrosion, dirt or some other debris. Make sure you clean it up completely before reassembly.
Hi Bill. So far I have not been able to find a manual, but I will keep looking.
In the mean time, if you want to give it a try, it appears to me that the circular piece that has the fingers that hold the light globe is probably put in place to hold the globe by a "turning" motion.
If you were to reach up and grab this ring and gently turn it counter clock wise I bet it would turn perhaps 1-3 inches and disengage the fan body.
Makes sense that the manufacturer would make it easy to change light bulbs and viewing the fan, this would be about the easiest way to do it.
I would assume the glass globe is NOT fastened to this ring in any manner, so if you do decide to try this, be ready to have the glass globe release from the holding ring.
I will let you know when/if I find a manual.
If you decide to try my solution and are satisfied with it, I would appreciate a Thumbs Up rating from you.
BTW, nice fan.
Paul
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
