Question about KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator
Clean out drain line
Not draining from the refridgerator
  • william h tanner
    william h tanner Jun 12, 2019
    Replace plastic bladder which had a small leak when pressed button for filtered water causing water to accumulated under bottom drawer. Remove all 3 drawers to access bladder.
    Top Expert:
  • KitchenAid Master
  • 63,390 Answers
I use a coat hanger I straightened out .
Posted on Mar 08, 2015
SOURCE:
The small hole at the back of fridge keeps icing over how do i stop this from happening?
I usually use very hot water alil at a time onto the hole drain spout, and I have a soft long flexable tube that I insert into the whole ( the condensator) to clean out the blockage and debris. can use coat hanger but be very careful as can damage the tube drain line. unplug the drain line from bottom of drip pan and place towel under it, u can also try to blow into the flexable tubing down towards the drip pan if its not solid
Feb 16, 2015 | Kenmore Refridgerator Air Flow Diffuser...
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
Water sitting in bottom of refridgerator and won't drain
Hi, Your drain line is clog up. Please clean it then.
Regards
Mar 23, 2011 | Refrigerators
Water leaking and freezing at bottom of freezer in side by side Maytag model # msd2454gr refridgerator.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 25, 2010 | Maytag MSD2454G Side by Side Refrigerator
Our refrigerator has started to leak water outside the refrigerator in the front. What could be causing this?
from inside refridgerator, or from below?
could be your condensation drain pan or the tube from the refridgerator to the condensate drain pan is stopped up. Have to take lower access panel off back of unit.If it has an icemaker, the water line could be leaking.
Mar 14, 2010 | Whirlpool 18.2 cu. ft. Top Freezer...
Cannot found drip pan, about once a day I see a pool on water on floor on freezer side
take out bottom basket,if it's frozen in melt it out with hair dryer,usually when this happens the drain is blocked and water will be outside of freezer door you have to melt out drain then blow out the drain line i use a steamer,you can try pouring hot water down drain line but alot of times slime forms in there and it has to be blown out with steamer or getting some kind of hose like the water lines used on the refridgerator wter lines and blow through it to unblock it,check it by pouring water down drain to see if it's clear
Nov 08, 2009 | Hotpoint HSS25GDMWW Side by Side...
Refridgerator side not cooling. No air movement.
vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Jul 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water dripping down inside from bottom of freezer
clean the drain line out,its a tube on the back of the refridgerator
Apr 26, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
GE Refridgerator leaking
it is possibe the inlet to the drain line may be plugged.The defrost water cannot run down the drain line to the pan on on the bottom.Also make sure it is level
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Doe's not defrost into lower drain pan.
Your drain line is clogged, just clean it out and you should be fine
Jun 26, 2017 | Kenmore Refrigerators
KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Logo
363 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
