Question about Fisher Paykel EcoSmart GWL15
JUST BOUGHT THIS UNIT and it will not wash
The unit fills and then starts to wash but then beeps and the second wash light, first rinse, second rinse, and spin lights are on. If I advance the cycle to rinse it will finish the cycle. Can someone help me figure out what we did wrong in set up?
  • 1,294 Answers
Re: JUST BOUGHT THIS UNIT and it will not wash
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
0 characters
3 Points
WTW4850XQ spins for a few seconds, then quits
Place the unit in diagnostic to do this make sure machine is off turn control knob to the left at least 3 times to clear now turn knob 3 clicks to the right 1 left 1 right all lights should light up do this within 6 seconds if you don't get lights repeat process I do this everyday so be patience once all lights are lit turn to the right until done light is lit press start button you will now see lights flash in varying sequence the way to read this the lit fill/sense light is the f code, wash light =8, rinse =4, spin=2, done=l when fill/sense light is not lit this is the second halve of the code example F7E1 you would have fill/sense lit, rinse=4, spin=2,done=1 F7 code, non lit fill/sense done=1 okay you may have more than 1 code it will continue to read the same code until you turn the knob once to the right the control will hold up to 4 codes at a time once you find the codes we'll go from there
Feb 04, 2014 | Whirlpool Washing Machines
Machine will fill and wash , but will not fill and rinse
Dec 09, 2013 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
Washer will fill and drain but won't wash and rinse
Check for a modular unit in the machine that controls the wash action of the machine. If it has malfuctioned there will be no power for the motor. Check with the spares departtment if your machine has this unit
Mar 02, 2013 | Haier HLP21E Top Load Washer
Washer does not fill
What is the model number of the unit?
Nov 30, 2012 | Washing Machines
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Washing machine fills and washes properly then when emptying machine stops then starts does not rinse properly no problems when filling only emptying does not do full cycle beaps constantly with 3 lights...
Hi just read your posting.Now when the machine is beeping the lights that are lit will be in a row of 8 lights,Starting from the left to right which lights are lit when the machine is beeping,Is it the 1st and 5th or the 3rd and 7th ---etc---?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 08, 2010 | Fisher and Paykel Washing Machines
Getting stuck on rinse light and beeps second by second
Mrs Vargas, if you wash on 'warm' you're using both hot and cold water mixed together. If the cold inlet valve is faulty (not uncommon) the machine will fill with hot water alone. When the machine gets to rinse, it can't advance because F&P machines rinse only with cold water. If the valve is faulty it can't fill. So it stops!...Not a big job for a tech....Good luck....Nomess
May 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Brand new Front Loader not washing
well if its spinning and not washing, that does sound like aproblem with unit and not what your doing, id call a service company to figure it out, thats why you bought new, not so youd repair it
Mar 29, 2008 | Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
53 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
