I have a panasonic PANASONIC PT51SX60A. The blue convergance is off on all for corners. I need to get info on the menu system to get to where the grid comes up to converge each sqaure
Our Samsung DLP 50" TV has green checkerboard type lines running through the screen however,...
(More)
Our Samsung DLP 50" TV has green checkerboard type lines running through the screen however, the PIP (picture in picture) works fine. What's wrong?
i have a panasonic model pt-43lc14 tv i keep getting a message on the screen thats says a filter...
(More)
I HAVE A PANASONIC MODEL PT-43LC14 TV I KEEP GETTING A MESSAGE ON THE SCREEN THATS SAYS A FILTER CHANNGE IS RECOMENDED AT THIS TIME, THE TV WILL SHUT DOWN IN ONE MINUTE, WHICH IT DOSE. I TOOK THE WHOLE TV A PART AND FOUND NO REAL FILTER THAT COULD BE REPLACED I BLEW OUT EVERY THING WITH AIR BUT STILL GET THE SAME THING, THERE MUST BE A WAY TO RESET THIS MESSAGE THANKS HARVEY
model # wd-52628: does not turn on, i inpluged it & left it unpluged for about ten minutes...
(More)
model # wd-52628: does not turn on, i inpluged it & left it unpluged for about ten minutes then plugged it back up & the timer light in the front panel flickered on & off until it the light stopped.last night when i was watching it, the tv would skipp picture frames for a while then would work fine for about 5 mins. the tv is a 2006 model so do you think it might be the lamp?
