The ARROW #506 T50 staples work perfectly. I've used both 3/8 and 9/16 sizes. They are on Amazon at
https://www.amazon.com/Arrow-Fastener-50624SPTP-T50-Staples/dp/B001KOVZQ8/ref=sr_1_5?crid=3FR4QFTDVRY37&keywords=arrow+t50+staples+3%2F8&qid=1636149518&sprefix=arrow+t50%2Caps%2C176&sr=8-5
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Typically you do not open these up. Makes it difficult to remove stuck or wrong staples. I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws. My T50 Arrow stapler is over 20 years old. Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works. Good luck!
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Take out the screw/nut combo @ the end of the gun where you load the staples. The whole rail that holds the staples will then come out and you can then get the little devils of the nested, jammed, rousted up staples out by sliding them out with a screwdriver. Don't jam the screwdriver into your fingers/hand when doing it.
