Check if the oven timer is on auto mode. If it is, turn it on to manual mode .
Remove the power cable from the outlet and wait for 20 minutes. As you plug your oven back in, the oven timer should reset as well .
Hold the timer buttons down at the same time to reset the timer .
Meter the thermostat out and see if it's open circuit .
Take the top off and inspect the selector switch and see if there are any signs of burning on the switch . How to Repair ' Smeg duel fuel range cooker A1-7 Oven not working. (how-to-repair.com)
When you refer to resetting it are you talking about turning the mains power off and then back on? Or are you talking about resetting the electronic timer? The electronic timer must be in the manual mode for the oven to work. Turn the oven on and play with the timer. When the oven indicator light comes on you know the oven is working.
Hello everytime the power goes off & then comes back on my oven won't work until I turn the knob for the timer around as far as it will go then back again. My oven is rather an old type but maybe if you reset the timer or turn it that may help. Or check the meter box as well. dee
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
hi
The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
