Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop does not come on . charger working and tested. no lights nothing dead
  • Anonymous Dec 02, 2007
    My Laptop will not turn on. Charger works no problem but nothing else is responsive.
    Please help
  • 85 Answers
If you've tested the power pack and are sure it is good, and the battery gets no response either, you've got hardware problems, obviously. Unplug the machine from the powerpack, and remove everything that can be removed; battery, all cards, all cables, and, turning the machine over, open the hard drive and any other bays and remove every hardware device you can find. Leave only the memory in. Then, try to power it up; if you get activity and power lights, it is a hardware short in one of the removed devices. Otherwise, you probably have a pulled cable or cracked power connector somewhere in the powerline.
If all else fails (danger - may trash the machine) unplug it (obviously) and try to remove the lower laptop casing to expose the spot where the power connector plugs in. Check this area carefully for cracked or melted plastic, and, if nothing obvious seems wrong, continue the disassembly checking for anything amiss (loose cabling or ribbons, maybe a plastic mounting pin that has broken off somehow). If you do all this and find nothing strange, the motherboard current overload or overheat sensors (if the motherboard has them) may be faulty, or any number of other (unfixable) things. If you get that far with no results, find the biggest geek you know (think electrical engineer) and throw yourself on his or her mercy. :>)
Good luck...
Posted on Nov 16, 2007
This acer is completly deaa.getting a lot of answers but pc needs to be on it is dead no charger no on light nothing.
take out the battery and try it with just power supply ONLY connectetd to it no printer, nothing. If it still does not come on AFTER you hit the power button and NO lights test the power supply. If the power supply is good then the DC jack might be damaged. AT this point have it serviced or time to replace laptop. Good Luck.
Nov 06, 2015 | Acer Computers & Internet
Acer aspire 5552 completely dead no power lights or nothing, my charger works fine.
Please remove your hard drive and reboot your laptop. If your laptop displays the BIOS screen, then your hard drive is dying or dead. Also, unplug the main battery to test it.
Feb 28, 2014 | Acer Aspire 5552-3691-24271 Laptop
How do you test for a bad motherboard
Basically testing the motherboard is a process of elimination. Unfortunately for laptops it can be pretty tricky. First thing to test is the charger. Most chargers have an indicator light on the box midway through the charging cable. Check to see if there is a light, and if so is it on?
If the light is on then the charger is probably OK. The next step is not so cut and dry. If there are no lights AT ALL then it is probably one of two things -
1. The DC power jack where you plug the charger in has a bad connection. This is relatively common and is a pretty cheap fix IF you know someone who can solder a new one for you.
2. The motherboard is bad - laptop motherboards are costly to replace and often you are better off buying a new machine
The problem is in diagnosing which it is. They both have identical symptoms, and the only real way I can think to discern between the two is to try the fix for number 1. and if that fails then the motherboard is likely dead
Nov 21, 2013 | Computers & Internet
Completely dead laptop.
sometimes you just need to remove the battery then power-up the unit using its charger.
Jul 05, 2013 | Toshiba satellite c660
I cannot turn Asus netbook on - not charging, no indicator lights on
Could be a duff battery, does happen. are you. do you have a ampre meter to check charge
Jan 28, 2013 | Computers & Internet
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
When i but the battery in the charger the orange and the green light comes on and i left it in for a long time and the battery was only charged a little bit whats wrong
This has happened to me. The transformer in the charger is dead.
you can test the charger by plugging it in and using a multimeter to test for current.
if you get nothing, it is dead.
You will need to get a new charger pack.
Apr 24, 2010 | Water Heaters
Dead laptop
hi guys...can you try to remove the battery then plug the AC/Charger then see what happen..only charger no battery pack in Laptop...
Apr 05, 2009 | Acer Aspire 5920-6335 Laptop
My gateway mt6839b wont turn on anymore
Gateway was working good went upstairs came back NOTHING BLACK SCREEN....
My gateway screen was constently black every time I powered on nothing no bios, nostart up no warning..The board has indicating lights to follow the start up power light on, battery light on, then the disk drive....but thats it normaly the harddrive reader light comes on but nothing.... So detached every component and tested individually..... come to find out one of my 2 ram slots is damaged not the chips...this could be your problem..try
Skillz Unlimited MDA
Nov 20, 2008 | Gateway MT3705 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
200 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
