Have you installed the stitch selector pattern module for the patterns you want, seated it properly as outlined on page 52 of the instruction book following all 7 steps? (Page 54 identifies the knobs and lever's that need to be moved to successfully install the pattern module)
If that is done correctly, then selecting a stitch is done with the stitch selector lever being moved under the letter corresponding to the stitch you are trying to select. (Shown beginning page 55) You also need to move the stitch length knob as indicated.
You will need to be sure you are following the instructions very carefully as there are a number of settings that need to be made to ensure you get the stitch you are trying to achieve.
Do you just need to attach it to the machine? Or are you having trouble using the foot itself?
It attaches the same way the other feet attach. Remove any foot that may still be attached to the machine. On the buttonhole foot look for the small silver pin that sits on the sliding piece with the small red line marks on it. Lift up your presser foot lever and attach the buttonhole foot's silver pin the same way you would attach any other foot.
As far as using the foot itself place your button on the back sliding piece snuggly till it fits in without falling out, adjust as needed. Pull the bottonhole lever down (it's located on the machine opposite the side of the presser foot lever) so that it rests behind the first lever on the buttonhole foot (small plastic piece raised on the left hand side of the foot that doesn't move). Slide the feed dog switch on the back of your machine so the feed dogs go down. Select your stitch and go. The machine automatically stops when done.
I just figured out how to use the buttonhole feature today. Make sure where you insert the button is towards the back of the machine. Pull down the button hole lever and make sure it's between to two plastic notches. The buttonhole lever will actually be pressed against notch B as described in the instructions. Insert your material and let the bottonhole foot down. You will to play with the stitch width and length to get the right size opening. I hope this helps!
It is the switch that is connected to the arm that may not be working properly which in turn send the wrong signal to the display.Check the arm and look for any kind of switch connected to it..Try to move it and see what happens or if the error disappears..
Personally I don't have the experience with a buttonholer attachment, however I do have several slant Singer machines. I'd suggest that you go to yahoo.com and click on Groups. In the search box put in singerslantsewing and join that group. Members are a diverse group of Singer enthusiasts, some repair guys there, and they are happy to assist, should you join and post your problem. There are other groups for Singers, but this group is dedicated to the slant needle models.
