Question about Packard Bell Computers & Internet
Monitor says off mode
I switch my PC on and it shows on the tower system that its on but the monitor doesnt come on the light stays on amber and when i press menu on the monitor to turn the light to green it says that the monitor is in off mode. Ive tried unplugging everything and replugging it but nothings worked, ive pressed all my keys on the keyboard to see if it comes on and still nothing. But when i switch the power on at the tower system i dont hear the sound that says its loading up. Any Ideas of how to fix this problem. thanks
  • 458 Answers
SOURCE: LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Posted on Jun 02, 2008
  • 461 Answers
SOURCE: In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Posted on Nov 17, 2008
  • 10 Answers
SOURCE: okay im having a probblem with my lcd monitor and
Sounds like the monitor is not getting a signal from the tower.
Do you have another monitor/LCD screen that you plug into your tower? That will tell you if the LCD is the issue or the tower.
If it is the tower that is at fault, then you need to try and figure out if your video is separate from your motherboard. Hopefully it is separate, that way you can get that replaced. If not, then it means that your video card is integrated onto your motherboard which is much expensive to get fixed.
Hope this helps.
Posted on Dec 08, 2009
SOURCE: I had to take my computer in for repair and turned
The first thing to check is , the Power, are ya sure it's plugged in OK, are ya sure that socket is working, try something else in that outlet to prove, check the power cord is pushed right in, Check ya on the right Video connector on the PC, make sure all conns are correct. Try the monitor on another base unit, try your base unit on another monitor. If all these are OK then ya Monitor has turned it's toes up sorry.
Posted on Jan 20, 2010
  • 1189 Answers
SOURCE: monitor going to sleep problem
  • Hi, The Monitor as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. If this solution to the problem was of help? Let me know by giving a "Helpful Rating", thanks, and have a "Great Memorial Day!"
Posted on May 30, 2010
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Oct 13, 2012 | Computers & Internet
My computer has recently decided to stop working. I can turn on the tower and the monitor to power it up and the tower does it's normal thing like it is working, the screen on the other hand stays...
If you mean you didn't get any display in your monitor the first solution is u must reinsert your memory and memory slot.if still have the same issue confirm your monitor is connected to your tower properly.if you still have the same issue just replace your memory (ram).thank you.
Sep 05, 2011 | Compaq Presario 5000 PC Desktop
If this the light is solid amber in the front of the computer.Try doing the following steps
1. Disconnect the power cable from the back of the system tower. Press the power button on the tower 30 seconds.
2. Reconnect the power cable to the back of the system tower and power it back on.
If the amber light is on the monitor power button and the tower power button is off or blinking amber it could mean that it is a bad power supply.
Thnaks for using fixya
Aug 10, 2010 | Computers & Internet
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Amber colored power light on eMachine W3503
The amber power light indicates that your computer has been "sleeping" or "hibernating" and usually all it takes to restart the computer is tapping a key on the keyboard. If this is not the case, try holding the Power switch down for 6-10 seconds to force the system off. Restart in Safe Mode and try to find the settings for Sleep/hibernate, open the control panel and open the Screen Saver. Select "Change Power Settings" and set it for "Never" on sleep and hybernate.
Nov 10, 2009 | E-Machines W3503 PC Desktop
Monitor led light goes from green to orange will not respond
Your video card or on-board video is kaput. If it worked fine on the other system, but not working on this one ... then you've blow the video.
One note: When the computer is ON, do NOT unplug and re-plug in the monitor. You'll blow the video card.
Luckily, add-on video cards are cheap and readily available ...
Jun 12, 2009 | Compaq MV 540 15" CRT Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Monitor doesnt come on , but the power light goes from amber to green. then comes on after 20-30mins maybe.
Maybe update your display drivers. PC appears to be slow.
Make sure you don't have a bunch of apps that auto start.
Do you hibenate your PC?
Same issue if you connect monitor to another PC?
If issue follows you to a different PC it says monitor. If it doesn't it says the first PC (that monitor is currently connected to) had a cpu/memory or a driver issue.
Good luck
Oct 25, 2017 | Sony SDM-HX93 19" LCD Monitor
Computers & Internet Logo
151 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
