Question about Samsung Blackjack SGH-I607 Smartphone
PDA DEVICE My PDA has no sound coming in and the volume is all the way up.
    Problem Solver:
  • 9 Answers
Try this:
Start -> Settings -> Profiles -> "Normal"
Sounds like you might be on the "silent" profile. Good luck!
Please reply if this doesn't work for you and we can go from there!
Posted on Nov 13, 2007
0 characters
3 Points
I have external GPS button in my HTC touch p3452 pda . . how to get get gps data from this ??
u need an external gps device bought separately and then trhu bluetooth u can communicate with this software in ur HTC , u have external bluetooth device or not
nowdays GPS is coming builtin so there is no need to purchase separate reciever but in ur PDA it is not built in
pls rate me WELL for info !
May 20, 2009 | HTC Touch P3452 Smartphone
Axim x30 won't come up
The Dell Axim X30 be soft reset by pressing the "Reset" button (from the stylus tip) on the rear of the unit, below the battery.
If the Dell logo in blue background lights up and then goes off again, its probably the brightness setting of your unit. Once the device has started up, just press and hold the jog wheel (the volume wheel above the headphone jack on the left side of the PDA) and press the UP directional key in the front bottom of the PDA. Every press of the up key should brighten up the screen a bit.
If the above solution does not work, you probably might need to hard reset your device.
WARNING: A "hard" reset wipes the RAM and returns the Pocket PC to its factory defaults. You might (mostly) lose all your data if you perform a hard reset. Do not hard-reset your device without having a backup of your data.
The procedures for hard resetting your ppc is given in a very detailed steps in the following page:
Apr 24, 2009 | Dell Axim X30 Pocket PC
Hi there, I Like to upgrade in my I-Mate JAQ OS WM 5 TO OS WM 6,1 or 6,5 if its is possible.Please show me how to do this. Thank you, Aleksandar
Hi, I'm afraid there is no offical or unoffical ROM upgrade for your PDA yet (ROM is the place where the PocketPC operating system is stored, and each device model has a different ROM so sadly you cannot use any other Windows Mobile 6 ROMs with your device.). I am giving more details about this issue to make it clear. Still you can follow the forums time to time to check if someone makes a ROM for your PDA. Basic problem is unlike most of the PDAs, your PDA is a non-HTC based PDA. I hope this helps. You can still download some PDA software to use your device more efficiently (Most of the PDA softwares are designed for working on both WM5 and WM6, since your device uses WM5, you won't be having a problem.).
Details of your PDA: (
Unoffical ROM forum: (
Offical ROM website: (
Apr 18, 2009 | i-mate JAQ Pocket PC
No sound from the device
no rigtones no sound from media player profile might be on vibrate or silent check it by pressing volume button , other wise try resetting the device
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to for latest Rom update downlaod and update backup ur data first
and if still problem persists check ur speaker on the back of ur device it might be faulty try connecting headphones with it if sound is coming then ur speaker is faulty windows is ok
Jan 25, 2009 | HTC Touch P3450 Smartphone
Microsoft Money etc. Sync Problem with iPAQ hx2495b
Dec 02, 2008 | Dell Axim X51v Pocket PC
Sound Problem on ASUS A636N
The problem is related to TomTom software. There are two methods to solve this problem.
(1) You can choose to install TomTom 6.1 which has solved the sound problem if TomTom V6.1 is available for end user.
(2) Find “BtCoreIf.dll”in Windows directory and rename it to "BtCoreIf.old”. Then, reset the device to solve the sound problem.
Nov 17, 2008 | ASUS MyPal A636N Pocket PC
My tytn 2 has on sound;ring tone ,audio playback even in bluetooth mode how to fix
the volume for phone might be off
there are 2 volumes, one for phone one for pda
Sep 06, 2008 | HTC TyTN II Smartphone
Are you using a headphone or the Pda's speaker?
The speaker could be damaged or disconnected - try connecting a headphone to the Pda to see if the sound works.
Feb 22, 2008 | Toshiba e740 Pocket PC
Connecting to bluetooth
Restore your PDA to factory defaults and try to make the connection again. I think it will work.
Dec 29, 2007 | i-mate JAQ Pocket PC
Poor reception for T830
Your Pda doesn't have a soft re-set button located next to the battery?
Jun 23, 2007 | Fujitsu Siemens Pocket LOOX T830...
Samsung Blackjack SGH-I607 Smartphone Logo
111 people viewed this question
Top Samsung PDAs Experts
Ronald Thompson
Charlotte Byrams
Charlotte Byrams
Are you a Samsung PDA Expert? Answer questions, earn points and help others
