Question about Canon PowerShot A75 Digital Camera
Canon A75 Canon compact displays picture like a cracked window and shutter will not operate and will not playback. Powers on, lens extends OK, batteries OK. Tried with two different cards with same result. Nothing appears on LCD screen except this cracked window effect. Any idea what could be wrong ? Looks terminal to me.
My powershot A75 is only displaying fuzz like a bad tv reception when in picture taking mode, display works fine in playback. any idea how to fix this?
This is known problem of ccd imager failure in Canon A75 camera and ccd imager will be replaced to get correct live view to take fresh pictures.
Canon offers free of cost ccd imager replacement, click Canon CCD Imager Advisory for details.
Apr 08, 2010 | Canon PowerShot A75 Digital Camera
Pictures completely dark. memory card ok. batteries ok. display of saved pics ok. Have reset defaults.
It's most likely a dead CCD or stuck shutter inside the lens. CCDs use to die on this camera - factory fault. You should contact Canon - they used to offer a free replacement of the CCD.
Hope this helps!
Oct 09, 2009 | Canon PowerShot A75 Digital Camera
Canon s21s
Think that you mean the S2 IS? If so, Canon has not yet to offered an advisory repair of that particular problem (although many people think they should as this seems to be quite a common problem for the S2). There are however some simple things that you can try to revive your camera from the likely "stuck shutter" problem that you're experiencing. See this blog article.
Sep 27, 2009 | Canon PowerShot A75 Digital Camera
Screen is black on playback & picture mode
Have you tried taking pictures when the screen is black? Do the pictures also come out black? If so, try putting it in any mode other than auto and turning off the flash (don't want to blind yourself for the next step). Next look down the front of the lens and take a picture. You should see a little flicker in the center of the lens as the shutter opens and closes. If you see this flicker, and you're still getting black pictures, then you likely have again encountered failure of the CCD. Canon will fix this again for you for free. See the following:
But if no flicker or movement is seen down the center of the lens when you took the picture, then you likely have a stuck shutter. Canon will not fix this for free. But no matter, there are a couple simple fixes for this that don't require opening the camera:
Jun 21, 2009 | Canon PowerShot A75 Digital Camera
My shutter will not open. The power button presses in and nothing happens. I have since got a new battery that was the problem, shutter still will not open. Camera is not operative, please...
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Jun 19, 2009 | Fuji J150w Digital Camera
LCD screen is blank with a purple line on the left side of screen
Its is problem of bad ccd imager and this part will be replaced in your Canon A75 camera.
Canon will repair A75 camera free of cost.
Click Canon CCD Imager Advisory for details.
Mar 17, 2009 | Canon PowerShot A75 Digital Camera
DisplY Issue
No image in capture mode ( camera mode )with no problem in playback is typically ( assuming the lens and shutter work ok ) caused by faulty ? dead CCD sensor...replace.
Sep 03, 2007 | Canon PowerShot A60 Digital Camera
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A75 Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
