Question about Dewalt 7.2-18.0 Volt One Hour Charger
Change 120v chager to run on 240v
What components do i have to change on a 120v charger to run on 240v
  • MickaByte Nov 13, 2007
    The charger model is DW9116
  • Anonymous Dec 06, 2008
    I have a Dewalt 7.2-18.0 Volt One Hour Charger 120V and I want to convert it to 240V
    Champion:
  • 313 Answers
All you needs is a step tranformer from 110v to 220v ac
Posted on May 28, 2008
  • 1,113 Answers
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Posted on Jan 30, 2008
I purchased remington shaver in US now it not working properly and not getting charged. where do i have repairing centre in hyderabad
Many Remington shavers sold in the US are only for use with 120V. Voltage in your country may be 220V-240V. If you attempted to use a 120V charger in your 220V electrical outlet without a voltage converter, you have probably damaged the charger.
Chargers can be purchased at shaveroutlet.com. You will need your shavers model number to select the correct cord. And, you may need to use a voltage converter if the replacement you get is for use with 120V
ShaverOutlet com ShaverOutlet com Cords Chargers Stands Shaver Replacement...
Feb 27, 2016 | Remington MS2-390 Electric Shaver
What to do if a 120v machine gets plugged in to a 240v outlet?
Just buy a new one. Every electrical component has been stressed to the point of destruction. Any fuse if there is one is there to blow in the event of a dead short, but you applied double voltage to every component.
Jan 16, 2016 | Pioneer Elite 7.1 Channel, 980 Watt, 3d...
I want to change 120v charger to run on 240v.What components have to be changed?
Can't be done.
Even if there was a safe way to put power to the neutral wire, the fact is you would still be running more than twice the power through it, and it would blow up. It would get much hotter.
Nor would the charger put out 7.2 to 18 volts any more.
It would put out over twice that.
The only way it could be done is if the unit was intended to also be run on 240 volts, and had a European selection setting switch.
Mar 12, 2011 | Dewalt 7.2-18.0 Volt One Hour Charger
Can you put a aussie 240 volt plug on an US battery charger
Look at the specs on the label, if it says that the charger is capable of taking a 240v input then you can change the plug and use it at 240v with no problem. If it says 120v then you won't be able to, you'll want to use a transformer or some other 240 to 120v supply.
lp
Dec 26, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
How to wire a intermatic timer T104 240 v to a 120v?
T104 is 240volt timer.
Timer has terminals A 1 2 3 4
T-104 clock motor must receive 240Volts to operate.
Clock motor wires are white-colored and can be seen connected to terminals 1 and 3.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/images/Back-of-WH40-2b.jpg
There are two work-arounds for using T104 for 120V.
1) Diagram 1 showing how to change wiring:
http://waterheatertimer.org/images/T-104-control-120V-Load-500.jpg
Move 240V clock motor wires to terminal 1 and A.
Connect 240V Hot leads to terminals 1 and A. This will power the 240V clock motor
Hot wire going to 120V load connects to terminal 2. This wire will be turned on each time timer turns on, and 120Volts will power the 120V load.
To complete 120V circuit, neutral wire that comes from neutral busbar in breaker box connects to 120V load.
To control additional 120Volt circuit, run jumper wire from terminal 1 to terminal 3.
Connect Hot to second load to terminal 4.
2) Second method is to change T104 timer into T103 timer:
http://waterheatertimer.org/images/T-104-control-120V-Load-2-5.jpg
Replace T104 240V clock with identical 120V clock motor from Grainger
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Neutral wires connect to terminal A.
Hot wire from Breaker connects to terminal 1
Hot going to Load connects to terminal 2
Dec 26, 2010 | Intermatic T104 24h 208-277v Mechanical...
Dear sir I am trying to connect Model Et104, my questions are as follows: I am having a problem connectiing your system. Both power source 110v and 220 volts have to connect to your system???? If my...
Fixya answers questions about other people's products.
I specialize in timers.
Intermatic is changing their product line
I suggest you download the manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
The manual is generic across all the ET100 series products.
The manual does not describe individual models.
The instructions are on the timer door.
Look for the clock voltage.
The clock voltage tells the story of your timer model.
NOW lets say your clock voltage is 120V.
I believe you suspect the clock voltage is 120V.
To make this timer work with your 240V cable, there are 2 methods
Method 1) To meet code, run a white wire from nearby 120V receptacle.
This is a Neutral wire.
Connect the Neutral to terminal 1
Connect one leg from the 240V cable (1 of the 240V wires) to terminal 2 and that will complete the 120V circuit and the clock will run.
This is true because each leg of a 240V circuit is actually 120V, and only when the two legs are combined do they produce the 240V circuit
Method 2) Connect bare ground wire to terminal 1 and to grounding screw
The bare wire connects to the Neutral busbar in the main breaker box, so it will complete the 120V circuit just as described above.
This is not code, but your clock will operate.
Then connect one leg from the 240V cable to the terminal 2
IF your clock is 240 V, then connect both legs of the 240V cable to terminals 1 and 2
7:59 CST Add a comment if you need more assistance, I will be here later this evening
Nov 06, 2010 | Intermatic INC ET104C 24 HOUR ELECTRONIC...
Drawing
OK, sorry, because my internet connection went down for near a month, so ...
No problem for that, just give me your e-mail address.I will e-mail you ASAP.
Jul 03, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Changing Dewalt charger from 120V to 240V
all i can say get a seperate step up transformer fron 110v to 220v.then just plug in charger to the step up transformer. make sure that u have 2 consider the frequency in ur country.
Dewalt 7.2-18.0 Volt One Hour Charger Logo
1,660 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
