Question about RCA F36650 36" TV
Gerald i have 21 inchess colord tv problem is no power.
  • 1,694 Answers
Verify service number from back of set.................
Probable bad IHVT ( aka flyback transformer) and possible
shorted horizontal output transistor........T.
Please let me know if # is F36650 YX01.............
Posted on Nov 13, 2007
How to pix daewoo 21" FLAT PANEL TV NO POWER
Here's how to pix it: Usually a fuse is on the power supply module inside the tv. You'll have to replace the module.
May 13, 2014 | Samsung DLP HL-P4663W 46" Rear Projection...
BPL TV MODEL FQR 21 don't start due to moisture
i have a cpu but my monitor has been broken so i wanted to connect my Bpl feb 21 tv can i?
Sep 09, 2009 | Televison & Video
DiamondMax 21 80-GB ATA/100 Hard Drive didn't get recognized as 1st drive or 2,3. do i need any software.
Use a partition manager to see if the drive is recognized. If it is not recognized, you may not have the jumper setting correct. If it is a master drive, set the jumper for master drive. same for slave or cable select
May 05, 2009 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
No picture
If your TV is less then a year old, still cover under manufacturers warranty, if not the solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to
Nov 28, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
MC50 Scanning
Try a soft reset by pressing the reset button on the back of the unit, this will often re-enable the scanner.
Also go to Start>Settings> Symbol Settings to test the scanner operation.
Apr 21, 2008 | Symbol MC50 Pocket PC
No sound - no video on TV
if you're hooking your VCR via analog video input of your TV then check that the yellow colored video wire goes to yout TV video input, will also be colored yellow inside the terminal. The white and red color inputs are for audio. Likewise the output of your VCD will have the same colord code Yellow for video, red/white for audio (stereo). After setting this up, select your TV function to video in, be sure to check your video input channel as well if you're having more than one video input. Video 1 or 2 or 3. Make sure your VCR is powered up when you start to setup your TV function select.
if you're hooking your VCR to your TV via RF signal (over your TV tuner) You need to scan the right frequency to get it tuned to your TV channel. Cabling willbe via RF antenna input of your TV and RF antenna out of your VCR.
Mar 17, 2008 | Televison & Video
Hi. It will be easier to help you if you tell us the make & model of your tv set.
Sep 21, 2007 | Televison & Video
RCA F36650 36" TV Logo
43 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
