Disconnect the battery and then the wires on the charger. Drain the transmission (left cover). After that, you can remove the shift lever connection and the clutch cover. Disconnect the clutch cable from the clutch assembly. Now you can remove your complete primary cover. After all that you will want to remove the two screws that hold the starter to the engine. Then simply put everything back in the reverser order using all new gaskets and seals and fill the transmission back up w/the proper amount and weight of oil.
