Question about SanDisk Sansa e250 MP3 Player
It shows Sandisk logo and freezes there
My sansa e280 8gb+2gb micro sd shows the "Sandisk" logo when turned on, then it goes black and white.It remains that way and won't play.
  • 626 Answers
Remove the SD card and try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Nov 13, 2007
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
Sansa c240 (1GB) MP3 Player: i have a sandisk sansa c240 and a 2gb micro sd car...
You Can Download Free MP3 From Youtube By This Site :
If you didn't found Your Favorite Music In Youtube Try These Sites : or
May 17, 2010 | SanDisk Sansa c240 MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
SanDisk Sansa Express MP3 player stays at SanDisk logo
You may need to get a firmware update from this web site:
Remember that you need to back up all of your information before doing the update.
Jan 01, 2009 | SanDisk Sansa MP3 Player
Sandisk Sansa goes to blank screen. No display and not working
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Mar 26, 2008 | SanDisk Sansa e250 MP3 Player
Micro sd 4gb card problems.
Check the Sansa tutorials at
to make sure you have followed all the steps first.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
Mar 22, 2008 | SanDisk Sansa e250 MP3 Player
Memory stick not identified.
The memory stick probably is not the right type. The Sansa only takes SD Micro chips. However, IIRC Micro only goes up to 2GB. So, if you have a 4GB chip is must be a SD HC (High Capacity). Unfortunately, these do not work in the Sansa.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Hack!!! please help!
You device is too full. You need minimum 6MB for the "music database". The more music you have, the bigger the database needs to be. Try freeing up 30MB or so, that should solve it. Please add to the question, dont select NOT HELPFUL if this didnt work. Best of Luck.
Sep 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
62 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
