HP Officejet 6700 Premium E-All-In-One Logo
D
David Leshock Posted on Mar 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I RECEIVE a fax, the screen says INCOMMING FAX from the sender, AND it shows AUTO ANSWER: ON. There is a button for ACCEPT, which if I hit it, will answer the call and print the fax. The problem is the AUTO ANSWER does not answer the phone. I have done everything to make it work. Power down the system, change number of rings to answer from 2, to 3 to 4 to 5, nothing works. I have restored all factory settings, no help. I have changed the telephone line to the two wire specified, no help. My machine USED TO automatically answer the incoming fax, but now it does not. Any ideas?
Darr 247
Level 2:
Scholar:
New Friend:
  • Expert 149 Answers
  • Posted on Mar 08, 2015
Darr 247
Expert
Level 2:
Scholar:
New Friend:
Answers
149
Questions
0
Helped
24611
Points
334
You need to talk to HP tech support... to do a proper reset you need to access menus that are meant for tech support and developers only. If you "brick" your OJ using those menus on your own (including instructions from anyone here), it's considered customer damage and voids the warranty. If you post your request at the link below, you should get a PM from an official HP tech support person telling you how to do the reset.
Officejet 6700 premium won pick up faxes
My C309a will not auto answer even after I've reloaded the drivers, gone through the tools to reset the default settings and reset to answer on 2 rings. You can manually answer a fax.
Hello Marie! Welcome to FixYa!
To receive and answer a fax manually, Follow the given steps:-
1. Make sure the product is turned on and you have paper loaded in the input tray.2. Remove any originals from the document feeder tray.3. Press the Setup button and Press the Down Arrow to select Basic Fax Setup , and then press OK .
4. Press the Down Arrow to select Rings to Answer , and then press OK .Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the productanswers. Or, turn off the Auto Answer setting so that the product does not automatically answer incoming calls.5. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.6.Press the Down Arrow to select 5 or 6 rings, and then press OK .7.Press the Home button to return to the main screen.
When you hear fax tones from a sending fax machine, do the following:a. Press START FAX Black or START FAX Color on the control panel.b. When prompted, press the down arrow button to highlight Receive Fax Manually, and then press OK.
After the product begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
I hope you have a clear picture in your mind.
Marie, If you find my service helpful for you then please don't forget to Rate the Service as "Five Stars" and give Words of appreciation as Feedback
Thank You for taking my service and using FixYa
Fax machine is able to receive faxes, but not able to send them. There is a "No Response" message every time I try to send a document.
Hi, i think your fax machine works fine, A "no response" message indicates that the receiver should accept your fax by hitting on the start button (normally its a green button) for you to able to send a fax or if no one in your friends location is receiving it. In this case you might as well set your fax machine to auto receive fax, defends on your fax machine's model. i hope this helps.
1helpful
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
3helpful
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Fax machine will not receive faxes. Sending okay. Comes up with busy signal at sending point.
Check menu settings and confirm the machine is set for automatic answer. If its in manual mode, you have to hit the start/go button when the fax rings to accept the transmission.
Stopped receiving faxes ten days ago. Can still send faxes. Senders say it just rings and rings. Calling the fax by phone confirms many rings, then fax belltones. What do you think is the problem?
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
I can send fax but cant recieve fax
You have not told us which model fax you have but most machines have a receive mode selection. Your machine may be set to 'manual' receive. It will only receive if you pick up the phone and hit the start buton. The phone has to be connected to the machine. Look on your machine for the receive button. It may be marked as 'auto receive' and 'manual receive'. Select 'auto' so the machine will answer. It may be marked as 'fax mode' and 'tel mode' if so select 'fax mode''. It may also have a selection 'ans mode' you don't want this as it assumes that you have an answer phone connected to your machine and it waits until the machine answers before it detects incoming fax. Good Luck
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
tray.
3. If you are currently on the phone with the sender, instruct the sender to press
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
1helpful
Receiving a fax
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Able to send fax cannot receive fax
make sure phone line is pluged into line on fax,make sure fax is set auto.there should be a button on fax panel that say's receive mode.
k24674
Grand Canyon Tech
Grand Canyon Tech
