Question about Casio AW80-7AV Wrist Watch
Analog setting i dont know how to set the analog clock to the right time... it doesn't have the normal dial like a regular watch does.... how do i do it? please help me out guys... i really need to be able to use this so i can get to work on time tomorrow...-Hip_shot
  • 1 more comment
  • Tahoist Feb 18, 2008
    on an old Speed Memory 100 , the digital time can be set intuitively, but how do I reset the analog watch hands?? Just replaced battery after many years of non-use. Watch is very old, Still runs great.
  • Anonymous Mar 09, 2008
    I need to set the analog time on the aw81d-7av
  • JJswan Apr 03, 2008
    how do I set the analog / digital time on this watch? My dad lost the manual.
Thank you very much you help me alot ... thank you..
Posted on Sep 05, 2008
The solution is in the user manual: pres "mode" six times, then press "adjust". The minute hand can only advance, by pressing "search", holding it pressed or pressing "light" and "search" at the same time. When you are satisfied with the settings, press "adjust" again to finish the procedure.
Posted on Feb 23, 2008
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
Nov 19, 2016 | Able Watches
I just bought a police kickers timepieces watch i dont know how to set the day i've tried hundreds of time but its not working can some one help me !!
Since you have stated ABSOLUTELY nothing about provinance... model, year... owners manual POLICE being a pretty decent watch from the UK (I'm going to skip right on past the AUTHENTIC notion... Chronograph (shown).
If your your watch is a REGULAR knock-off (replicant)... t has the miyota movement...
A highly precise and reliable motor
in it's own right.
(sets very much like the high end valjoux cousins)
It is a crown-set... typically a three position stem set.
Force nothing... !!
Some GENTLY unscrew the crown... others will pull out
to set: 1, TIMW 2, DATE... THREE (back to normal -closed).
In the closed position
The stop/start butons do precisely that on those SUB-DIALS.
In the SET positions the start/reset buttons are used to ZERO those sub-dials (press & hold... then individual clicks will move each hand to zero).
Hope this helps!
police quartz movement Bing images
Jun 25, 2016 | Police Watches
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
How do i set the anolog time
Go to "setup" pushing mode sometimes then right down push should move analog clock
May 20, 2012 | Casio G-Shock World Time Analog Digital...
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
Today is Tuesday, March 8. My Caravelle by Bulova watch says it is Wed March 10. How do I get this corrected since the only manual that came with the watch doesn't tell me anything. My watch is a square...
do not pull the stem all the way just half way out. Turn clock wises the date should move. move to correct date. counter clock wises for the day. For the analog hold down the set mode button until it starts to blinking to change number with the start and stop. to change what is blinking press the mode button
Mar 08, 2011 | Caravell Bulova Caravelle watch
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
Keep pressing 'select mode' button until you get to H-SET. Than hold 'adjust' button until screen starts to blink. Now you can adjust analog clock by pressing 'start/stop (search)' button. When you are finished, just press 'adjust' button once. That's all.
Feb 18, 2009 | Casio AQ163WG 1BV Casual Sports Watch with...
Casio telememo 30 syncronising analogue and digital time
To set the analog time to match the digital time...
There are 4 buttons: top left=A, top right=B, lower left=C, lower right=D
Get the watch in timekeeping mode (where it shows the digital time or date)
Press C six (6) times
Hold down A until the current digital time begins to flash
Press D repeatedly to advance the analog time, one minute at a time.
If you need to advance the analog time at high speed, HOLD D DOWN.
To return to regular timekeeping mode, press C
Set the digital time so that it matches the analog time, since you can reset the seconds easily.
Dec 28, 2007 | Casio DB360G-9A 30 Pages Telememo Watch
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Casio AW80-7AV Wrist Watch Logo
316 people viewed this question
Top Casio Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
