Back to:
Tags:
D-Link DES 1005D  5x10/100 Mbps Networking Switch
2 pc connected but wont allow both on internet at...
posted by JoinFixYa on Nov 13, 2007
2 pc s connected but wont allow both on internet at once - it disconnects one to allow the other on - but i thought when both are plugged in to D Link router -both should get access at the same time to internet ??
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by Mizack, posted on Mar 09, 2008
i still can't connect both computer to internet at same time
Best Solution
posted on Nov 13, 2007
Thanks for Trying (70)
mabulok
Rank:Master Master
Rating: 79%, 42 votes
Set up both pc's with dhcp. To do this, right click (My Network Places) in the start menu and choose properties. Right click your network connection and again choose properties. Click Internet Protocol (TCP/IP) and then select properties. Choose (Obtain an IP Address Automatically). Then (OK) and again (OK). Do this on both pc's.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 2 pc connected but wont allow both on internet at once:
I don't want to Accept this solution
Can you Help with these Networking Hubs and Switches problems?
yellow steady, for a while after flashing all ports etc.
I have an N-tron 9000 that has two 9006TX's in the last...
lucas 7 SA seven pin need wiring diagram
hi, when i am trying to dial then after some time...
Got a call from a tenant that his thermostat was reading...
Loading problems.
Repair Service
Find Networking Hub and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
