Question about SanDisk Sansa e250 MP3 Player
Sansa e250 problem
My sansa e250 works fine except for up the top of the screen it is white lines that annoys me i watch videos i hope u can fix it
Re: sansa e250 problem
I had same thing. i called up customer support and u gotta annoy da heck of them. keep calling them about it send pix of it screwed up den they will help. if dey think itz in bad condition and not fixable, they will send a new one.
Posted on Dec 06, 2007
0 characters
3 Points
Player Freezes on black screen format won't work
Delete everything by formatting it then activate the hold switch, press the power button, turn it on, download a fresh new firmware from the site and drag it to the player then connect the player to the computer, then initiate the firmware. try to get the latest one.Hope dis works. RATE PLZ
Jun 13, 2008 | SanDisk Sansa e250 MP3 Player
Lcd screen shows white screen and black marks
you can fix the problem by having the original sansa files when you format it it deletes everything
get a friends sansa files or do this
and just because it would be a pain looking for the original files i uploaded here for people who deleted them put these files into a folder named
REFS--no files
and put them in into 1 folder named SYSTEM--make it hidden then put it on sansa
then create a music folder make it hidden
then create photo folder with thumbnail and my album folder make my album hidden
then create pictures folder make it hidden
then create playlists folder make it hidden put this file in it
make a record folder with 2 folders named radio and voice
make a folder video
captilize all these except the one listed below
make a tmp folder
this should work :)
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Playing videos
well you can try to first search on its a great uppdater there but if you need a new firmware you can search on
rockbox got some firmwares to but i only recomend that if you are a littel bit more advanced user hopes it helps :D
Jan 12, 2008 | SanDisk Sansa e250 MP3 Player
Video converter
I like to use Aimersoft Video Converter for it supports all popular formats like AVI, MPEG, 3GP, M4V, WMV, etc. Besides, it has powerful function of edit like trim, crop, etc. You can free download it for trial here:
Hope to help you.
Oct 11, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
Problem when starting
Hello Devildeiss, Try to format the unit. Follow the steps 6 and 7 of the solution i presented here: Note that all data on your unit will be erased! But maybe that exterminate with your current problems. Good luck!!! Eduardo.
Oct 03, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
