SOURCE: 2003 santa fe 4 cycl clutch replacemnt
The fastest way is to remove the rad and move the engine ahead enough to change the clutch. Be sure to support the trans. Otherwise you will be into a lot of work under the truck. Frankster016
SOURCE: manual hyundai santa fe
The best way is to go to the dealer they may have to order one. Go to the parts department.
SOURCE: transmission problems
might be your shift sensors. trans shop will charge you $50.00 to run a test. if its simple you can do it your self. but if its major let them do it. your insurance should cover this.
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
SOURCE: 2001 Hyundai Santa Fe - Engine Code P1602, stuck in gear
Im having the same problem with my 02 Santa Fe. How do i go about fixing this problem? And is it costly? Please help
