Question about Tefal UltraGlide Easycord FV4256 Iron
It doesn't get hot - Tefal UltraGlide Easycord FV4256 Iron
  • 22 Answers
Re: It doesn't get hot
Check out if the wires are connected properly.....
Posted on Nov 17, 2007
0 characters
3 Points
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Morphy richards iron lights up all fuctions working but does not get hot
1)If the iron doesn't heat, make sure power is on to the outlet, 2) check the electrical cord, and 3) check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary
God bless you
Oct 12, 2012 | Morphy Richards Irons
Where can I order the steam trigger part that is broken. I need the part number. It is a Rowenta DG980. Thanks
Rowenta RS-DG0123 Knob Trigger, Blue
Carefully pry off blue handle cover on top with a popsicle stick.
A quick (maybe permanent) fix while waiting for your part: you can "weld" the plastic trigger back together. It doesn't have enough surface area for glue. Position the break back together. Secure parts so they don't move. Heat a medium-small flat blade screwdriver until it will just melt the plastic with a gentle touch. Touch the tip parallel to the break and melt a shallow groove about 1/4 of the way into the break. You should be centered on the break so you melt a bit of each piece. This will be the start of melting the two pieces together. Now, as you do each side of the break, use the flat of the blade to "trowel" the curled up plastic back into the groove you just made. Be careful not to distort the side that activates the switch. Ours is holding so well that I keep the new part in case this ever breaks again.
Less is more: use only enough heat to melt the plastic with a gentle touch. If it's red-hot you went WAY too far. You can always try more heat, but if you fry the part, you are done until your new part comes.
Sep 14, 2011 | Rowenta DG-980 Iron
Plug gets very hot and sometimes the iron doesn't work
your plug needs replacement. you have to put high wattage plug ,because iron has 1000watts or 4 amphere load.
Aug 15, 2011 | Rowenta Professional Luxe DM880 Iron
I just purchased a used EuroPro Steamer model EO8020. After about 5 minutes of use on the steam setting, the base starts making a loud rattling sound. Doesn't sound healthy to me. Can you...
It's just normal to hear that because heat inside is generating and steamer is on it's way to be ready for use. Hot air is about to be release and so rattling sound occured.
Need not to worry about it, the steamer is new and functioning normally.
Good luck
Jun 25, 2011 | Euro-Pro Steam Generator EP8020 Iron
Tefal UltraGlide Easycord FV4256 Iron Logo
106 people viewed this question
Top Tefal Irons Experts
Ryan S
Ryan S
Are you a Tefal Iron Expert? Answer questions, earn points and help others
