Question about Tefal UltraGlide Easycord FV4256 Iron
Teful ultraglide easycord fv4260
Hi my iorn light comes on and off i fiddle with the cord sometimes i get a blue flashing light is this normal lost the manual can you help
Re: teful ultraglide easycord fv4260
If you move the cord up/down/side to side and the iron works then you have a problem with the cord-damaged/broken or the pins(bent) and the wall power outlet pins(gone wide) are not making a GOOD connection.BE CAREFUL YOU WOULD/COULD TRIP THE FUSE AND ALSO DAMAGE THE POWER OUTLET-BURN/ARC AND CAUSE SOME DAMAGE.check the pins and connection.This will be a step by step checking of the cord and connection pionts.
Hope this helps
Posted on Nov 17, 2007
0 characters
3 Points
Why red light flashing pro express no water
This is a very common problem, water may have made its way into the mother board. Called tech support and they sent me a new one.
UK - 0345 602 1454
Jun 10, 2014 | Tefal UltraGlide Easycord FV4256 Iron
Replace worn electrical cord
Terminal block is fastened/secured with body by a screw but before removing the terminal block from body, make sure that the iron element terminals are also disconnected. this can be done by opening the screws on other side of the cord terminals-3 in number as also in the cord. Otherwise the terminal block would not come out fully.In any case you normally do not need to remove the terminal block.
Apr 05, 2012 | Tefal Irons
2 year old iron lost power while ironing. Plugged it in to other working outlets. Light remains off.
It has defective parts, either the wire is open or the heating element also a defective plug cord.
It can be check by a continuity tester, if you have and knows how to use it.
If not, call or ask who has knowledge in appliance or electrical repair for assistance.
Thanks for asking.
Jun 28, 2011 | Tefal UltraGlide Easycord FV4256 Iron
Iron will not heat up
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
Jun 06, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Re: cleaning the iron
Here is a tip that will help you with cleaning the bottom of your iron...
Cleaning a Steam Iron Soleplate
Mar 07, 2010 | Tefal UltraGlide Easycord FV4256 Iron
I need descaling instructions for Tefal Ultraglide easycord55...Mislaid instruction booklet....Thank you
thank you solved de scale instructions for Tefal Ultraglide easycord 55, found manual on net....
Jan 09, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Tefal UltraGlide Easycord FV4256 Iron Logo
193 people viewed this question
Top Tefal Irons Experts
Ryan S
Ryan S
Are you a Tefal Iron Expert? Answer questions, earn points and help others
