Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Oragon ini virus
Ie title bar says oragon ini
  • Fidel Tolentino
    Fidel Tolentino Nov 13, 2007
    Thank you so much but the thing is i cannot open the task manager. i know the virus manipulated my system and disabled my task manager even the run tab. can you help me on how to access my task manager or gain control of it again. i really appreciate it!!!
  • jsphmlndrz Dec 02, 2007
    Aside from internet explorer, my taskbar has also an oragon sign. And all my files have also oragon on details..
  • 4,889 Answers
You guessed it right this is caused by a virus called taga lipa are..
It doesn't harm the system in anyway but its annoying..I suggest that you follow the manual procedure to remove it..Do as follows..
Open My Computer -> Tools Menu -> Folder Options -> View Tab:
Select: Show hidden Files and Folders
Uncheck: Hide Extensions for known file type and Hide Protected operating system
Click Yes Then OK.
You will see an autorun.inf and FS6519.dll.vbs in all your harddrives. Delete ALL of them.
If it says that something is using the program. Press Ctrl+Alt+Del and go to processes, end ALL wscript.exe
Open MSConfig and under startup, uncheck the trojan’s startup entry, [FS6519].
Click Start > Run and then type regedit
delete [HKLM\Software\Microsoft\Windows\CurrentVersion\Run\FS6519]
key, and modify [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Window Title”,”TAGA LIPA ARE!”] key to remove the nuisance in IExplorer.
OR go to Edit -> Find and type FS6519.dll.vbs.
Edit the found registry by selecting the name, ryt click and modify, remove the last two strings which is wscript.exe and FS6519.dll.vbs and click OK.
If finished, press F3 and it will search again for another, just do the same thing until nothing is found in your registry.
If you are done with the FS6519.dll.vbs, its time for the TAGA LIPA ARE! be edited in your IE, type the string on the search again then it will show up the IE title … modify then type anything you like or better delete it.
DOnt hesitate to comeback if you need more help..
Posted on Nov 13, 2007
  • eagle338
    eagle338 Nov 13, 2007
    Looks like your system is infected with multiple viruses...But first check if you are able to run mscongfig..Start->run->type msconfig...If its not opening then its infected with some other virus.http://windowsxp.mvps.org/Taskmanager_er... as more than one virus is present run a full advice that perform a full system scan..preferably with kapersky or AVG
  • eagle338
    Brigadier General:
  • 6,966 Answers
The oragon ini is a variant of Taga Lipa Are, not really a virus but more of a nuisance. If affects/changes Internet Explorer, some parts of the Registry, shown in the MSConfig as FS6519.dll.vbs and modifies the Autorun.inf plus a few others.
Like some Pinoy fun "viruses" none of the popular commercially available Anti Virus software can detect or if detected can not remove/repair damages. More often it requires a bit of several steps which needs to be manually done.
Rather than go to a lengthy procedure, please refer to this site, you can try here also and/or to this site . As you can see, this has already been well documented.
Good luck and kind regards.
Mabuhay!
  • Louie  Role
    Louie Role Nov 14, 2007
    Hi again,
    If I may add to eagle338.
    1. To re-enable Task Manager - Start, Run, type "regedit" (if run is missing use All Programs, Accessories, Command Prompt).
    Hive: HKEY_CURRENT_USER
    Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
    Type: REG_DWORD
    Value: 1=Enablethis key, that is DISABLE TaskManager
    Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
    2. To restore RUN in Start menu - Right click on Start, click on Properties, tick Start menu, click on Customize button, click on Advanced tab, scroll down and check "Run command", OK, OK
  • Louie  Role
    If for some reason #1 of 2nd posting doesn't work, try this:
    Click Start
    Click Run
    Enter gpedit.msc in the Open box and click OK
    In the Group Policy settings window
    Select User Configuration
    Select Administrative Templates
    Select System
    Select Ctrl+Alt+Delete options
    Select Remove Task Manager
    Double-click the Remove Task Manager option
    Since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
2 Suggested Answers
osborne382
  • 306 Answers
SOURCE: i'm having a problem removing the virus oragon ini.pls help.tnanks so much!
try this. its a free trial, I use it to get the hard ones out then unistall it.
Tip
CHANGE INTERNET EXPLORER TITLE
<span>1. start -&gt;run-&gt; gpedit.msc <br /><br />2. choose User Configuration, Windows Settings, Internet Explorer Maintainance, Browser User Interface, and doubleclick Browser Title. <br /><br />3. Activate Customize Title Bars, and type something in there. Doesn't matter what. Let's type: QWERTY. Click Okay. <br /><br />4. Fire up Reg editor. (start, run, regedit) <br /><br />5. goto HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main. <br /><br />6. Look for the key: Window Title. There you'll find the value: Microsoft Internet Explorer provided bt QWERTY. <br /><br />7. Change this key to anythig you like and exit regedit. <br /><br />8. Fire up IE and look at the titlebar</span> <span><br /></span> <span>WinXP security: If you don't do steps 1 to 3, you won't find the Window Title key</span>
on Apr 04, 2011 | Computers & Internet
I trying to find a bar & chain for a Mcculloch eager ****** saw. Only model numbers I find are 60012416or 12-052701. Saw had 16" bar which has broken.Was using Oragon S54 chain.
Here is a good website for finding bar and chains from the Oregon website.After you get the part # you want you can always purchase from other source.
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Hope this helps.
Feb 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Window vista crash how do i fix it??
1.First be sure that ur side bar is closed,ie nothing is running in background.RIGHT click on side bar icon in system tray,chose EXIT button.U will get a message,asking if u really wants to close,click OK.
2.Check task manager to be sure that no Sidebar.exe process is running.if any one running,close it.
3.Open window explorer &paste following into location bar:%localappdata%\microsoft\Windows Sidebar
Sidebar gadgets folder will open with a file named Settings.ini.Once u re-lounch sidebar from Start menu, new settings.ini is created immediately.
With any luck, u should now have a new workink sidebar.
Apr 10, 2010 | Microsoft Windows Vista Home Premium with...
Title bar rahul the hacker
Click on Start >> select Run, type "regedit" without the quotes and press Ok. Registry Editor will launch. Expand the HKEY_CURRENT_USER hive, expand the software hive, expand Microsoft, expand Internet Explorer and then click on Main. In the right hand key look for the string named Window Title, double click on it and change the caption to whatever you want. Delete this string in case you want to set it to default.
Please rate this solution in case you find it helpful, if it doesnot resolve your issue, please post a comment and I shall try to post other solution.
Jul 14, 2009 | Computers & Internet
Virus
find someone who has a .357 Magnum, lol
Nov 30, 2008 | IBM ThinkPad T21 Notebook
How to remove desktop.ini virus from windows vista
it is not a virus... it is some kind of error... goto filehippo.com and download a software called unlocker... you can remove desktop.ini using that....
Nov 21, 2008 | Microsoft Windows Vista Ultimate Edition
Desktop.ini problem
there is no problem frm that file
it's nor virus no anti-virus will not delete it
u can remove it frm un-locker
download it from www.filehippo.com
ur's kishore chowdary
+919441133420
May 22, 2008 | Microsoft Windows Vista Ultimate Edition
Script Virus Removal particularly VBS.IE-Title.K
Eexecute regedit by typing "regedit.exe" in run command or command prompt.
Search and Remove the key value present in the reg'ed values in
HKEY_CLASSES_ROOT & HKEY_CURRENT_USER & HKEY_LOCAL_MACHINE & HKEY_USERS & HKEY_CURRENT_CONFIG , If present
this may present in /software/microsoft/windows
or drives/
Jan 18, 2008 | Microsoft Windows XP Professional
I'm having a problem removing the virus oragon ini.pls help.tnanks so much!
Nov 13, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
312 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
