Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I'm having a problem removing the virus oragon ini.pls help.tnanks so much!
Internet explorer title bar says oragon ini
  • 306 Answers
Re: i'm having a problem removing the virus oragon...
Try this. its a free trial, I use it to get the hard ones out then unistall it.
Posted on Nov 13, 2007
0 characters
3 Points
Tool bar for computer gone how do i find tool bars in my computer
"FILE, EDIT or VIEW" options on the top.
  1. Open Internet Explorer, and make sure that it is running properly. If you receive any error messages upon opening it, your best bet is to reinstall Explorer rather than customize the options as new add-ons have likely caused serious problems. If it runs properly, however, continue to the next step.
  2. Check to see that the menu bar is visible. If the menu bar is missing, you will have to make it reappear. Right-click anywhere below the "Title Bar" (the bar which shows the Internet Explorer icon and the name of the current website) and any other visible menu bars. Then be sure that the "Menu Bar" has a check mark beside it on the window that appears. Click "Menu Bar" if there is no check.
  3. Click on "View" in the menu bar. Then click on "Toolbars" from that menu. This will bring up a list of available tool bars. To make the one you want appear, simply click its name, making sure that a check appears next to the name.
  4. Restart Internet Explorer. Some toolbars will reappear immediately. Others require a restart. But restart the application anyway to make sure that your new preferences are saved.
  5. Reinstall any extra toolbar applications if they do not appear in the Toolbar menu.
Please try this and see if anything help's.
Jun 15, 2010 | Microsoft Windows Vista Home Basic for PC
The best antivirus that I am using and its free is ESET.
I was able to rescue a webserver which can no longer be connected thru remote desktop.
You can try that.
Aug 14, 2009 | Operating Systems
Presence of rahul the hacker in my web page with tittle bar
Try this
Registry Key: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main
Modify/Create the Value Name [Window Title] according to the Value Data listed below.
Data Type: REG_SZ [String Value] // Value Name: Window Title
Value Data: [Enter The Text Desired In Title Bar]
Exit Registry and Reboot
Hope It Solved Your Problem
Good Day
Apr 17, 2009 | Microsoft Windows XP Professional With...
Ressolving and getrid of antispyware"virus" and icons in the notification area of task bar
In internet explorer go to the tools menu and then internet options menu. Go to the programs tab and look for internet explorer being the default browser. Click make default. If you want you can take the tick out of the box which says inform you if its not default.
You may also want to go into control panel and choose add/remove programs and find the offending program and remove it. Be careful you dont remove anything else.
Feb 25, 2008 | Operating Systems
it's a virus, undetectable with antiviruses, there is a file named autorun.inf in the drive delete the file and recheck it.
Feb 07, 2008 | Microsoft Windows XP Professional With...
1 Answer virus
go to the site adawarealert dot com and download their software. it'll cost you $19.95 to register but the results are amazing!
Feb 03, 2008 | Microsoft Windows Vista Ultimate Edition
Script Virus Removal particularly VBS.IE-Title.K
Eexecute regedit by typing "regedit.exe" in run command or command prompt.
Search and Remove the key value present in the reg'ed values in
this may present in /software/microsoft/windows
or drives/
Jan 18, 2008 | Microsoft Windows XP Professional
My computer affected with virus trojan how can i remoove ?
first get any anti-virus I prefer F-SECURE, then load on your computer then update it after u pdate then perfom a full system scan then it will detect all the viruses,then choose delete option the it will remove all the viruses from your computer.Inform us after u try this solution.
Dec 16, 2007 | Operating Systems
Problem regarding internet explorer 6.0
k try this delete all temp files and cookies and restore the inter net explorer
to delete cookies and files follow this
open i-explorer ->in top->click tool->inter net options->general->delete temp files,cookies,clear history>
to restore the i-explorer follow this
open i-explorer ->in top->click tool->inter net options->click on advance ->in bottom click on restore default
and reboot the pc>if still the same issue then try with different browser
i hope this will help u rate me solved if this helps thx
Dec 02, 2007 | Microsoft Windows XP Professional for PC
Oragon ini virus
The oragon ini is a variant of Taga Lipa Are, not really a virus but more of a nuisance. If affects/changes Internet Explorer, some parts of the Registry, shown in the MSConfig as FS6519.dll.vbs and modifies the Autorun.inf plus a few others.
Like some Pinoy fun "viruses" none of the popular commercially available Anti Virus software can detect or if detected can not remove/repair damages. More often it requires a bit of several steps which needs to be manually done.
Rather than go to a lengthy procedure, please refer to this site, you can try here also and/or to this site . As you can see, this has already been well documented.
Good luck and kind regards.
Nov 13, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
60 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
