Televison & Video Logo
A
Anonymous Posted on Mar 06, 2015
How do I set up my DVD player on a Sony TV? I can't find input on the TV remote.
I'm not finding TV input on remote control. Can you walk me through it?
L Heme
Level 3:
Master:
  • Master 395 Answers
  • Posted on Mar 06, 2015
L Heme
Master
Level 3:
Master:
Answers
395
Questions
0
Helped
57422
Points
1163
You did not specify what kind of DVD player you are using? If it is a Sony DVD player it should be found by the TV automatically. Perhaps you are not plugging the DVD into the correct ports on the TV.
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec...
Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems
Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes.
1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are
Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s
Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls
Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k...
GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
  1. Turn on your Sony DVD player.
  2. Locate the code for your Sony DVD player in the code list provided with the universal remote.
  3. Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
  4. Enter the code for your Sony DVD player using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
  1. Turn on your Sony Bravia TV.
  2. Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
  4. Enter the code for your Sony Bravia TV using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
Cant find how to set tv to show dvd player
Look at your remote control for your set. Find a button that says "input" or "source". Use that to choose which ever input your dvd player is attached too. Model of TV and DVD player would help make the answer more specific.
1helpful
HOW TO SET UP SONY DVD PLAYER WITH HITACHI 42 LCD TV
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Can't get my Sony DVD player to work.
I was able to solve the problem by trying every device available on the TV set's Menu until I got it to work.
How to set inputs in Mitsubishi CS-35405
My cs-35405, only has input 1 and input 2, but has ant. A and ant.B So there are really 4 inputs. The input button on my remote, gives choice of these 4. Any vcr, dvd, cable or cable box, and satellite would be hooked seperatly on these. But to record TV, satellite or cable would need to go to recorder first and then toTV.
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
